No start!
Old Aug 28, 2011 | 03:43 PM
buckman123's Avatar
buckman123
No start!
Ok guys the track has been sitting for a few months with a bad tranny. So yesterday we went to get it running so we could move it up into the shop to put the new tranny in. I turned the key on and everything came on but the injectors don't buzz. It cranks but it won't start.
Thinking it was the FICM we took it out and rebuilt it. That didn't do it.
I have 48v on one stud, 12v on another and 0 on the other two.
If I hold the FICM power relay closed the injectors will buzz and the truck will start and run. But if you let go of the relay it dies. There's only 9v to the relay.
anybody know what it is. I am pretty sure it's a bad FICM but everything looked good inside the FICM. Could it be bad battories?
Thanks! Tranny is coming tomorrow so I need to get this going.
Old Aug 28, 2011 | 03:48 PM
huntinguy's Avatar
huntinguy
Subscribing.
Old Aug 28, 2011 | 05:30 PM
npccpartsman's Avatar
npccpartsman
Sounds like the batteries need a good charge if there's only 9V to the relay. There's a link in the 6.0 tech folder for complete FICM diagnostics. Also check the relay sockets for corrosion and check under the turbo for rodents. They love to chew the wiring.
Old Aug 29, 2011 | 09:46 PM
huntinguy's Avatar
huntinguy
Found the problem. there was a bad wire between the fuse box and the FICM power relay.
I'm the OP's son.
Bbegley83
17
Oct 2, 2019 09:55 AM
topkuz
Feb 16, 2017 09:36 AM
Padlock
Jul 1, 2014 11:19 PM
66 bronco roadster
1983 - 2012 Ranger & B-Series
Aug 9, 2012 08:29 AM
Hiflyer746
Mar 8, 2009 05:46 PM
