quarter panel replacement
Old Aug 27, 2011 | 02:32 PM
Rvr600's Avatar
Rvr600
I want to buy a damaged 2010/11 F350 for a personal project.
1 How do the front quarter panels come off the truck? Is it lots of work to replace them if the mounting points are ok? how do they mount?
2 What is easier to fix? Front damage? Roll over?
3 What do you want to avoid? frame damage? Cab replacement?
Thanks
Old Sep 1, 2011 | 12:23 PM
rr38690's Avatar
rr38690
1. If by front quarter panels you mean front fenders they are pretty simple, they just bolt on.
2. Front damage would most likely be easier.
3. cab replacement ist bad if you have something that will lift it and not damage it.
Old Sep 15, 2011 | 09:31 PM
dabaws's Avatar
dabaws
if you don't know how to pull off the fenders, you should be a little careful, usually when the fenders are damaged, the mounts need to be straightened out and pulled for new fenders to fit properly, well, that depends on the extent of the damage
AVOID frame damage, trust me on that one, you'll regret it once you take it for inspection
Last edited by dabaws; Sep 15, 2011 at 09:33 PM. Reason: answering the rest of his question
Old Sep 20, 2011 | 08:39 PM
96red4.9's Avatar
96red4.9
they are also glued on at the rear and are very aggravating to pull off. don't buy one with major frame damage! if you are looking at one hit hard in the front make sure you look for kinks in the frame behind the wheels on the bottom and inside of the frame. the frames are boxed and if they get kinked they will never come back out. personally i would look for one that's side swiped with no front or side structural damage. just one that needs a fender doors and bedside. that would be the easiest rebuild.
hoss73ford
Aug 30, 2015 08:02 PM
crewchief99
Jul 20, 2014 02:07 PM
AstroFab
Mar 5, 2013 03:14 PM
Ravenheart
Dec 28, 2010 09:39 PM
Cartman
May 26, 2000 04:25 AM
