fuel regulator
Old Aug 27, 2011 | 10:12 AM
bigrig410's Avatar
bigrig410
fuel regulator
Is a fuel pressure regulator absolutely necessary on a fuel bowl delete? What if any woudl be the negative effects of running lines directly from supply line to factory bowl to the fuel rails? I thought i saw a homemade setup without a regulator here on FTE.
Old Aug 27, 2011 | 10:26 AM
bigrig410's Avatar
bigrig410
I think i just answered my own question right after i posted it, should have thought about it longer. I don't think you would want 60-80 psi running all the way back to the tank, churning the fuel and possibly not leaving enough fuel in the rails to take advantage of the fuel bowl delete. Am i on the right track?
Old Aug 27, 2011 | 10:37 AM
timmyboy76's Avatar
timmyboy76
subscribing...
Taking a jab at this one, but if no FPR, then the fuel would likely pass right by the injectors in the rail. FPR, i think, is there to feed/keep fuel housed in the rails
Old Aug 27, 2011 | 11:07 AM
mueckster's Avatar
mueckster
The FPR is a metered restriction. Without one, you would have less pressure. A fixed orifice of the proper size on the return side would be an option to an "regulator", but the pressure would fluctuate more do to the demands of the injectors. I believe the the spring loaded regulator adds a dampening effect to the pressure to keep it more stable.
BigBlue92
1983 - 2012 Ranger & B-Series
Aug 15, 2012 10:30 PM
BigBlockFalcon
Aerostar
Feb 7, 2012 07:15 PM
dunerunner
Modular V10 (6.8l)
Feb 2, 2010 07:36 PM
rebel33382
Sep 9, 2009 07:25 AM
broncoII89
Bronco II
May 31, 2005 07:54 PM
