6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Replaced Engine NO TURBO BOOST
Old Aug 27, 2011 | 09:19 AM
jbenford's Avatar
jbenford
So I have an 08. I just put a new (actually used with 34k miles on it) motor in it. After I got it all together it started in like half a crank. Actually kind of scared me. I'm used to a 6.0 where u have to crank and crank to get them to start after any little repair it seems.
The truck would run and idle just perfect. The problem is when you go to drive it down the road there is no turbo boost. We drove it for 10-15 miles to see if it would come up but no luck.
Any suggestions where to start looking first??
Thanks for looking and helping!!!
Josh
Old Aug 27, 2011 | 11:25 AM
Ronin 5729's Avatar
Ronin 5729
Wow...you're going to have to give a whole lot more detail than that, and without any codes it'd just be spitballin' anyway...
Start with a code reader first off...can't believe there's no CELs...?
Old Aug 27, 2011 | 01:23 PM
senix's Avatar
senix
X2 on the codes. Also you can look at the simple stuff I the actuator for the high press turbo. Does it cycle? Look at the wiring connector for the turbos..is it attached all the way?
Old Aug 29, 2011 | 02:50 PM
jbenford's Avatar
jbenford
The only code it is throwing right now is P132b. P132B Turbocharger/Supercharger Boost Control A Performance
Thanks for the help guys
Josh
Old Aug 29, 2011 | 02:54 PM
senix's Avatar
senix
Electronics to the turbo. SRA module.
Check the pins going to the PCM make sure they are all good as well. Not pushed in or bent.
Old Aug 29, 2011 | 03:27 PM
jbenford's Avatar
jbenford
This might sound stupid but where is the SRA module? and where is the pcm?? Sorry to have to ask but just want to make sure I'm doing it right.
sgrol
6.7L Power Stroke Diesel
Aug 17, 2017 10:01 PM
STEELHQ
Dec 9, 2010 11:10 AM
exiled
Sep 1, 2008 05:48 AM
FLASH 13
Jul 26, 2007 04:19 PM
southernhick
Mar 6, 2005 08:22 AM
