replacement Bulb
Old Apr 3, 2003 | 04:09 PM
f_pumillo's Avatar
f_pumillo
replacement Bulb
Help!
I replaced the stock headlight bulbs with Street glows (HID's), nice performance difference. I am trying to do the same with the fog lights. Trouble is I have yet to find a replacement for the 9145's. Does anyone know of a replacement for these bulbs. It looks odd to have the cool blue on the headlights and old yellow glow from the fog lamps.
Old Apr 3, 2003 | 07:39 PM
DCSpecial's Avatar
DCSpecial
replacement Bulb
If the lights are the same as the ones on the SD which I'm pretty sure they are...........a 9005 bulb is what I have read will work for the fogs unless it is an '03. Just FYI, easiest way to replace them is to pull off the grill.
Hope this helps.
Old Apr 4, 2003 | 01:59 PM
jdadamsjr's Avatar
jdadamsjr
replacement Bulb
Dc Special gave u the straight scoop... u may have to modify the tabs, but it will fit and be much brighter than the 37w fog light !
Old Apr 5, 2003 | 09:51 AM
f_pumillo's Avatar
f_pumillo
Angry replacement Bulb
Thanks guys, The owners manual indicated 899's. I knew I should have spent the time to pull a bulb! Anyway $30 later, I'll try 9005's , and yes I will pull the bulb and check before I shell out more bucks. I need to save my dollars for guages and exhaust. The streetglow site had the right numbers, but no replacement. Anyway sounds like a trip to Walmart with Bulb in hand.
