Cummins swap
Old Aug 25, 2011 | 07:23 AM
USArmyTaterness's Avatar
USArmyTaterness
Cummins swap
I was looking at swaping in a 5.9l cummins into a 74' F250 High boy and i was wondering if any one of yall had done this at all and had a list of parts needed for the swap I plan on buying a junked truck to pull the engine and wiring and ect... I planned on mating it to a E4OD tranny with the adapter plate on the engine to be able to use a standard bell housing.
Any input would be greatly appriecated.
And before I get any brand name haters Ford does use cummins the the larger trucks as an option.
Old Aug 25, 2011 | 12:56 PM
78 PEB's Avatar
78 PEB
I am in the process of swapping the 5.9's little brother into my 78 F150 4x4. At this point, I can tell you that you will need the following:
1) E4OD with the small pattern bellhousing from behind a 302 or 6 cyl.
2) Cummins flywheel housing from a step van conversion
3) Cummins flywheel from a step van conversion
4) Cummins starter and starter spacer from a stepvan conversion.
Or you can go aftermarket on all the above............I just like using stock parts if possible on my stuff. The stepvan conversions were used on frito and bread trucks a bunch. You can find the bits and peices on ebay or at this website in the classifieds.
Cummins 4BT & Diesel Conversions Forums
The 4btswaps forum is an EXCELLENT source of info on swapping them in. Just introduce yourself properly on there and they are almost as willing to help you out as FTE members. Hope this all helps.............
Old Aug 25, 2011 | 01:38 PM
USArmyTaterness
Great info thank you very much. If anything comes to mind please let me know.
k_brenner
Engine Swaps
Jun 10, 2013 02:03 PM
USArmyTaterness
General Diesel Discussion
Sep 28, 2011 02:54 PM
oomph
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 30, 2010 08:00 PM
pjohn192
Engine Swaps
Feb 13, 2010 11:08 PM
averagef250
Jan 29, 2004 11:50 PM
