How much torque?
Old Aug 24, 2011 | 10:06 PM
corbin9191's Avatar
corbin9191
How much torque?
Hey guy's after getting my 4X4 fixed today my brother asked me a question that I don't know that answer to. He is wondering how much torque a 1999 7.3 liter powerstroke with manual tranny has in 4X4 low and the tranny set in low? I have a TS 6 position chip with the 140+ horsepower setting on it as will as a k&N cold air intake. this truck is just a F250 as well with stock gearing. Thank you!
Old Aug 25, 2011 | 06:59 AM
hotroddsl's Avatar
hotroddsl
Well 335 HP with 500ft/lbs of tq was STD I can't tell you what your tuner has claims of tq increaseses but rest assured you are putting at least 500ft/lbs to the ground if you can keep traction!
Jim...& fat Monty
Old Aug 25, 2011 | 09:54 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
To the OP....
Are you kidding about your location?
(see mine)
Back on topic though, all you have to do if you want a reasonably close estimate is multiply the net engine flywheel torque rating (in this case, about 500 ft. lbs.) and multiply it by the low gear ratio of the transmission (5.79:1), then by the low range ratio of (2.73:1), and finally by the final drive ratio (likely 3.73 in your case). Almost 25,000 ft. lbs.
That will give you axle torque. However, that is the maximum....of which you'll likely never see because you have to have the engine under full load at around 2400 RPM.
Just be aware that torque value is nearly meaningless and doesn't mean much of anything because you won't be getting a whole lot of work done at 4 MPH and your limited traction will really put a damper on being able to load the engine enough to make an actual 500 ft. lbs. at the flywheel.
Old Aug 25, 2011 | 01:45 PM
corbin9191's Avatar
corbin9191
Originally Posted by cleatus12r
To the OP....
(see mine)
What part of town are you in? I live up by the church. We have the two big diesels sitting outside.
Old Aug 25, 2011 | 03:17 PM
Mitch1407's Avatar
Mitch1407
"we have the two big diesels sitting outside" Country must be country wide- Brantley Gilbert
Old Aug 25, 2011 | 04:17 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
I have two big diesels sitting outside too!!!
Old Aug 25, 2011 | 05:30 PM
corbin9191's Avatar
corbin9191
Have to love those big FORD diesels
Old Aug 25, 2011 | 09:24 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
By where my friend's house burned down earlier this year....
I've seen the trucks while driving toward Big Timber.
Old Aug 25, 2011 | 09:42 PM
hotroddsl's Avatar
hotroddsl
I live by the Mormon church and I've got two big diesels sitting outside too! What a coincidence! Do you have a fat yellow dog?
Jim...& fat Monty
Old Aug 25, 2011 | 09:43 PM
corbin9191's Avatar
corbin9191
Yeah unfortunately, I did help the fire department and tried to help him get his vehicles moved away from his house. But 26 inches of snow on the ground does not help when you are trying to get things moved.
Old Aug 25, 2011 | 09:44 PM
corbin9191's Avatar
corbin9191
Jim...& fat Monty
No, but I do have a few big dogs running around here.
Old Aug 26, 2011 | 01:22 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Bad day for Dennis.
Old Aug 26, 2011 | 09:21 AM
corbin9191's Avatar
corbin9191
Yes it was.
640 CI Aluminum FORD
7.3L / 6.8L V8 Gasoline Engines
107
Aug 5, 2019 02:06 PM
ChrisFromTheForest
5.0L Coyote
Mar 14, 2011 11:16 PM
50calmike
General Diesel Discussion
Dec 22, 2007 09:10 AM
Roger_56
1997 - 2003 F150
Apr 9, 2006 12:27 AM
robduval
Offroad & 4x4
Jul 15, 2004 10:39 PM
