Ford Valdese
Old Aug 23, 2011 | 06:20 PM
Greg013's Avatar
Greg013
Ford Valdese
I have a 97 F250 with the 7.3 turbo...i have an oil leak at the back of the motor and i cannot find it...i dosnt leak when the truck is idling just when its being driven..i know its not coming from the turbo,any suggestions or comments are much appreciated thanks.
Old Aug 23, 2011 | 06:53 PM
F350-6's Avatar
F350-6
Welcome to FTE. Is there any oil in the valley? Is the pedestal leaking? Have you checked the plugs on the back of the oil rails?
Old Aug 23, 2011 | 06:54 PM
427 fordman's Avatar
427 fordman
Here's the plugs chris mentioned
Old Aug 23, 2011 | 07:19 PM
Greg013's Avatar
Greg013
this is the first diesel i have owned so those terms are foreign to me. Not sure where the pedestal is or the oil rail.And yes its down in the valley.And thank you for the welcome!
Old Aug 23, 2011 | 07:25 PM
Greg013's Avatar
Greg013
those lines at the back of my motor go into this brass looking deal with a bolt head on it..im really not this mechanically inept i'm just lost when it comes to diesels
Old Aug 23, 2011 | 08:22 PM
F350-6's Avatar
F350-6
Don't worry, you'll pick up the names soon enough. If you've got oil in the valley, you just need to clean it up with some simple green and low pressure water from a garden hose. Then watch and see if the oil starts to show up at the front, middle or back of the valley. There's a few common leaks we see. Most of them are from a ten cent o-ring, so narrowing down the location will help us tell you where to look.
And the pedestal is the thing the turbo bolts to. It's basically a stand / spacer between the engine block and the turbo. There are some o-rings above and below the pedestal that can leak if your oil is coming from back there.
Old Aug 24, 2011 | 06:47 PM
Greg013's Avatar
Greg013
Thanks ..that helped out a lot. I appreciate your help.
Old Aug 25, 2011 | 04:27 PM
quesey's Avatar
quesey
[quote=427 fordman;10730088]
knew i should have painted my motor yellow
Dwightttt
Mar 23, 2016 10:27 PM
Lliamspop
24
Dec 26, 2015 10:02 AM
flip67
Mar 27, 2010 11:29 AM
travisd
Feb 28, 2010 04:58 PM
ipkyss
Feb 24, 2003 11:36 PM
