power mirrors
Old Aug 23, 2011 | 01:30 PM
RobertJohn's Avatar
RobertJohn
Question power mirrors
If neither power mirror works is it the fault of the control switch on the drivers arm rest or what ?
I've moved my mirrors all over and can't get either one to operate..
Can you clean the control switch or what ?
Any help would be appreciated, btw the fuse is good, I checked that the first thing.
Old Aug 23, 2011 | 02:10 PM
BigAlsPSD's Avatar
BigAlsPSD
I've had good luck removing the switch and cleaning the contacts.
Old Aug 23, 2011 | 02:59 PM
CSIPSD's Avatar
CSIPSD
90% of mirror issues are the switch. People love to drive with the windows down, and they just get trashed.
Old Aug 23, 2011 | 04:55 PM
RobertJohn's Avatar
RobertJohn
I cleaned the contacts etc.. The switch seems to be bad as it hangs and won't go from R mirror to L mirror... So it seems like I'll look on Flea Bay and see what I can find..
Thanks for all the help..
Old May 7, 2012 | 03:36 PM
Lex2002's Avatar
Lex2002
I just ordered a replacement unit made by DORMAN from EBAY for $16 delivered.
Anyone know if you need to take the door panel off to replace or does it pop out?
Old May 7, 2012 | 03:40 PM
empiretc's Avatar
empiretc
it pops out. pull off the bezel, unplug the switch, and pop it out.
Old May 7, 2012 | 03:52 PM
Lex2002's Avatar
Lex2002
Me no undershtand.
So youre saying you dont need to pull the interior door panel off? You just pull it up out of the door?
Old May 7, 2012 | 04:29 PM
CSIPSD's Avatar
CSIPSD
Pull up on the front of the switch panel... toward the front of the truck. Grab the switch panel at the point and pull up. It will pop out of the door panel.
Old May 7, 2012 | 04:40 PM
Lex2002's Avatar
Lex2002
Ok cool. So it's essentially a plug....
Thanks much Mr.
Old May 7, 2012 | 04:48 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Does a single fuse run those mirrors? If so, what number? Thanks......
Old May 7, 2012 | 05:25 PM
CSIPSD's Avatar
CSIPSD
You can down load your own owners manuals here...
http://www.dieselbombers.com/ford-po...d-manuals.html
Old May 7, 2012 | 05:34 PM
Lex2002's Avatar
Lex2002
I dont see any manuals just some coffee Table books.
Old May 7, 2012 | 05:45 PM
CSIPSD's Avatar
CSIPSD
Sorry, got in a hurry and linked the wrong link...LOL
http://www.dieselbombers.com/ford-po...tml#post537971
Old May 7, 2012 | 05:57 PM
landmobile's Avatar
landmobile
Be sure to pull on the front of the switch panel as CSIPSD said. If you pull up on the back, the plastic tab that holds the switch panel in the door panel breaks, and you wind up looking like this guy >> .
Old May 7, 2012 | 05:59 PM
Lex2002's Avatar
Lex2002
Thanks Mr.
