Turbo Preventive Maintenance?
Old Aug 23, 2011 | 08:02 AM
redbug's Avatar
redbug
Hello,
2001 F250 7.3 4x4 Crew Cab 91,000 miles, E40d. Totally Stock.
I'm in the middle of the 50 cent fix. I decided not to do this job earlier and that was a mistake... I'm trying to check everything that's accessable while I have it apart.
Is there anything about the turbo that I should be looking at? How long will the turbo last? Will I be able to tell if its failing? If it does fail, will it leave me on the side of the road or will I have enough power to make it home?
Thanks,
Redbug
Old Aug 23, 2011 | 08:18 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
First off, you have a 4r100 trans.
Take the intake tube off the turbo and look at the wheel. Look for dusting of the wheel, and if there are any chips in the fins. Grab the nut on the wheel and see if you can move it side to side, a little side to side play is ok as long as it dont hit the housing. Try to move the wheel in and out, there should be no movement there. That turbo can last many miles so don't be concerned about it leaving you on the road as long as you keep on top of checking it.
Old Aug 23, 2011 | 08:57 AM
redbug's Avatar
redbug
OK, fins looked intact and shiny when I had a look last night. I'll check the play but visually everything looks good.
4r100, ok, I have a 4r100. Didn't know that. I do know its an automatic with overdrive!
Thanks.
Old Aug 23, 2011 | 10:24 AM
scottnchrissy's Avatar
scottnchrissy
I would check all the bolts. I just had my turbo out to put in new up pipes. Two of the four bolts holding on the exhaust side we backed out and a third was about half way backed off. Not sure how long I would have had before a failure but I am glad I caught it.
Old Aug 23, 2011 | 12:45 PM
73ferdf250highboy's Avatar
73ferdf250highboy
turbos dont really need any maintenance. check shaft play as said. in and out-no good.
gasses hit the exhaust wheel and slightly push it forward, as the pressure side builds boost- the compressor wheel is pushed back against thrush washer and bearing.
side to side is normal-since the shaft floats in oil. bb turbos shouldn't have any side to side.
turbos need really good air filters. always. and good oil pressure and and
my .02
kurt
Old Aug 23, 2011 | 04:37 PM
JOHN2001's Avatar
JOHN2001
The only thing you can do is make sure your EGTs are no higher than 300* before you shut the truck off. With a bone stock truck and if you were driving it easy let it run for about 45 seconds before you shut it off. If you were driving it like you stole it let it idol for about 2 mins
kameronth
43
Dec 17, 2017 08:24 PM
95_Dually
Sep 3, 2009 11:07 AM
triton185
Jun 29, 2007 06:09 PM
eric777
16
Jul 18, 2006 11:32 PM
