Whew, I thought something was wrong, yes, that was my first thought, sounds like it has a beefie cam. I have no tunes yet, I just put the injectors in this weekend. I was planning on mods shortly as soon as I recover from this weekends expenses. I can't tune anything without a tuner, right?
I also noticed like a touchy gas pedal, the truck slightly jerks when letting off the pedal.............
Reason: add on
The cam loop you are having is because you went split shot injectors to single shot...you need tuning to make it right...with proper tuning it will not act like a big block cam and shouldn't....at least get a hold of DP tuner and have them flash your pcm....
Yep. Excessive Pulse width at low load/RPM.
Also, your SOI (Start of Injection, also known as "timing") is too advanced compared to what split-shot tuning is commanding. Not a good idea to be driving it like that.
Yes they are a little louder. BTW, You don't list any tuning in your signature, did you get tuned for the single shots?
Yes I'm tuned, I've got several different chipsets tuned by the various different tuners in my area im now trying BEANS to see what their tuning can do with their injectors! If I can't get
Rid of the smoke with them I will go to the tyrant and start doing it myself
Jim...& soot covered yellow fat Monty
Reason: FUAUTOCORRECT
Sorry Jim, I was referring to the OP, since he had just put SS injectors in and I didn't see any tuning.
OP: A modified stock PCM flash would get you by, ultimately it's up to you and your budget as far as getting a chip or not, most will sell a chip with a modified stock chip and alone if you did not want to purchase other tunes at this time. $80 vs probably $200 is the cheapest chip you could get by with.
