Towing Help
Old Aug 23, 2011 | 11:25 AM
MCDavis's Avatar
MCDavis
Originally Posted by NotMyHusbandsF150
The pin thing on the back - there are two - one has 6 pins around a center circle... is that the 7 pin? The other has 4 pins. Is that right?
Looks like you have the factory towing package. That'll help your cause a little more, and the truck/transmission won't be so unhappy.
Old Aug 23, 2011 | 11:37 AM
stormsearch's Avatar
stormsearch
Yes, that is the 7-pin connector so sounds like you have the towing package. You can more easily upgrade with a brake controller. Though, I would seriously try towing something alot less weight beforehand. Never towing to something 5K+ lbs. is not something I would even enjoy. And yes at 5K+ lbs., I would highly recommend getting the brake controller and a trailer with brakes (not sure if the dollies are equipped though). I pull a 3500 lb. boat with the 5.4L and will never tow anything that weight or heavier without brakes over long distances.
Tylus has a better suggestion - use the U-haul truck to tow the Explorer and let the experience driver deal with the load. The money to upgrade the truck could be better used to get a decent diesel U-haul truck.
Shake-N-Bake
EcoBoost (all engine sizes)
Jul 20, 2015 11:52 AM
sonar_91
All Things Towing
Nov 6, 2011 06:57 AM
rcosta
Oct 21, 2010 01:45 PM
03fx4il
All Things Towing
Aug 28, 2010 07:47 PM
mj633
All Things Towing
Jul 3, 2004 10:30 PM
