Sponsored by: Auxito
Don't know which part to get for PCV problem
Old Aug 19, 2011 | 03:12 PM
GeekoSuave's Avatar
GeekoSuave
I've narrowed it down to part #6C324, however there are 2 of them.
I have a 4.6L V8, 98 F150, from the Windsor plant.
This is the link: Buy 1998 Ford F-150 Parts | FordParts.com
The two parts are completely identical in price, part number, manufacturer and everything, the only difference is on one, this is written below:
HOSE APPROX 17.4MM
I was thinking I'll just get the one that does NOT say "HOSE APPROX 17.4MM" on it, but I'd rather be sure.
Appreciate the help.
Old Aug 19, 2011 | 04:04 PM
cv18sro's Avatar
cv18sro
Just out of curiosity why dont you measure the one you have? What if the other one is shorter and you order the wrong one. If you do not have a metric tape, I do not either but I take a piece a string or twine if you can reach the entire hose length use the string to measure it, measure your length and convert it. There are all kids of online converters.
Old Aug 19, 2011 | 07:36 PM
GeekoSuave's Avatar
GeekoSuave
I'm actually not at the house right now, so the truck isn't around. I'll measure it as soon as possible. I'm going to put the description of the two parts on here so that everyone can see them. I didn't realize that the parts page would just redirect to the main catalog.
If it is not 17.4mm, will the other one be wider or thinner?? I've seen a lot of posts about these not fitting, but it seems that mostly I've seen that on Expys and one case where it was a '97 F150.
Anyhow, the descriptions for the separate parts are:
(8 Cyl. - 4.6L Windsor) - 4.6L
And the other is:
(8 Cyl. - 4.6L Windsor) - 4.6L; HOSE APPROX 17.4MM
Everything else matches, part number, price, description, the exploded illustration. Anyhow, I'll provide a measurement asap.
steve2003
1997 - 2003 F150
Jun 19, 2017 10:47 PM
ptf18
Oct 13, 2011 09:00 PM
jasonmerlo
Apr 13, 2007 01:37 PM
65f100xmas
Mar 30, 2006 11:19 AM
Kenworth
Oct 11, 2005 09:28 PM
