smog pump
Old Apr 2, 2003 | 05:25 PM
5Otruck's Avatar
5Otruck
smog pump
alright.. my belt is going bad aswell as my smog pump pully (keeps making a clicking noise), so im wondering if it would screw my computer up if i get a shorter belt that excludes the smog pump (ill just thow the bigger belt back on when its time for inspection)? the smog pump already isnt hoked up because when i did my exhaust i cut the hose/pipe the goes from the pump to the cat and just stuffed one of my old spark plugs up in there.
i got a 94 f-150 302 5-speed, dynomax headers, true dual flowmasters, k&n sys.
tom
Old Apr 2, 2003 | 06:43 PM
goofin's Avatar
goofin
smog pump
IF YOU REMOVE THE SMOG PUMP YOU NEED TO BLOCK OF THE INLET FROM THE PUMP TO THE HEADS. FORD MAKES A SPECIAL PLUG TO BLOCK THE OPENING. DEPENDING ON HOW YOU REROUTE THE BELT, YOU WILL NEED UP TO A 7" SHORTER BELT. LESS IF YOU JUST REMOVE THE SMOG PUMP PULLEY. AFTER LOOSING A CRANKSHAFT I DECIDED IT WAS TIME FOR A HEALTHY CHANGE. 347 CAME OUT AND A 393 STROKER WENT IN. LOST ALL SMOG JUNK, WENT TO CARBURATION. YEA YOU HAVE TO CRANK IT A LITLE MORE ON COLD MORNINGS BUT I HAD A INTAKE CRYING TO BE USED. GAS MILIAGE IS AS WONDERFUL AS CAN BE, 8 TO 10 MPG AT BEST
