Sponsored by: Real Truck
Rumble strip feeling
Old Aug 17, 2011 | 07:24 PM
crazyrwe's Avatar
crazyrwe
Hi, i'm getting a rumble strip feeling in the floor of the truck when i hit 20-30 mph, very noticable. i had truck aligned and checked out. I have the stock Conti's 18 inch. I have 28,000 miles and the 1 tire is worn more than the other 3 but not totally worn out. Shop said it was tires and just run them, but will prolly need new skins by winter. Any one ever get that rumble strip feeling, thanks.
Old Aug 17, 2011 | 09:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, from worn tires, just like your shop suggested.
Old Aug 18, 2011 | 12:14 AM
ak-angler's Avatar
ak-angler
The question is... why do you have irregular tire wear?
Old Aug 18, 2011 | 05:27 AM
drey04's Avatar
drey04
My truck did the same thing about two years ago... it was the driver's side front wheel bearing.
Old Aug 18, 2011 | 02:29 PM
crazyrwe's Avatar
crazyrwe
Well angler, the worn down one is from my hitting the throttle a bit hard as it was the drive tire, my own fault. But rotated them and had the same rumble strip feeling. As far as wheel bearing, all i can say is they checked front end, and don't know what other symptoms i would get from a wheel bearing other than noise.
wogdiml
Nov 19, 2010 03:52 PM
CyberJay
May 16, 2007 06:06 PM
1979FordF-250
2004 - 2008 F150
19
May 9, 2007 07:40 AM
tommomatic
Jun 4, 2003 09:55 AM
