coolant flush procedures
Old Aug 17, 2011 | 10:42 AM
xsportplyer's Avatar
xsportplyer
The oil cooler on my truck failed recently filling my entire coolant system with oil. After a lot of research i have decided to install a full bullet proof kit w/ cold weather adapters and an arp headstud kit as well as an upgraded radiator. I have been looking at procedures for flushong the coolant out of the engine block and heater core. Everything I have read says to run the engine during parts of the process to fully get out alll the old material. Seeing as I cant do that with ky bad oil cooler and i don't want to get the oil into my new components oce i put them on. Is there any thet good way to flush the block out?
Old Aug 17, 2011 | 11:21 AM
Elvis40's Avatar
Elvis40
What all are you planning on replacing? Water pump, heater core, radiator?
Old Aug 17, 2011 | 11:34 AM
xsportplyer
I'm replacing the radiator, hoses, degass tank, putting in a condesor mounted oil cooler, redesigned Egr cooler, coolant filter, water pump, replacing the oil filter with a screw on filter, head studs and head gasket, along with some other small parts. my main concern is getting the block and hear core flushed out completely without getting that oil in the new parts.
Old Aug 17, 2011 | 01:50 PM
IT_Dude's Avatar
IT_Dude
I have 2 new bottles of VC-9 if you're interested. I bought them a couple months ago for a flush, but didn't need them. My coolant must've recently been flushed.
Also, I'm the dude with the freeze plug blown, so they're in the process of flushing my coolant now anyway so again, I don't need them. I'm at 17202. I think I paid around $50 but I'd do $35 and you pay shipping. PM me if interested.
Old Aug 17, 2011 | 04:00 PM
_Me2_'s Avatar
_Me2_
How about flushing it out with tap water from the hose and one of those flush kits that install on the heater hose? You could probably flush out most of the junk with that and then do the proper flush procedure with distilled water when you get the new stuff installed.
Old Aug 17, 2011 | 04:12 PM
High Binder's Avatar
High Binder
Does a clogged oil cooler cause it to fail? Or what?
Old Aug 18, 2011 | 06:51 AM
xsportplyer
That's what I was thinking I just wasn't sure if anyone else had a better idea.
Old Aug 18, 2011 | 07:02 AM
xsportplyer
In my case yes. The oil cooler plugged and the excess heat caused the welds to break internally.
Old Aug 18, 2011 | 11:27 AM
High Binder
Wow, do you know what your oil temp was when that happened?
Old Aug 18, 2011 | 11:49 AM
xsportplyer
No I don't a buddy wctually had the truck when it died and i didn't have any sort of gauge. Part of my fix I am in the middle of is adding a edge insight system.
Old Aug 18, 2011 | 03:10 PM
High Binder
Good call on the gauges. I hope your install goes off without a hitch!
Old Aug 22, 2011 | 12:24 PM
FKNVA's Avatar
FKNVA
The Ford Tech used 3 gallons of Purple Stuff to flush out the coolant system on my 2004 6.0 after replacing the oil and egr cooler.
Old Aug 22, 2011 | 12:38 PM
Piolet's Avatar
Piolet
Simple Green HD could have been the purple stuff.
Available in jugs at Lowes, Home Depot etc.
It's mentioned specifically in a few Ford videos & TSB's if I remember rightly.
Old Aug 22, 2011 | 12:53 PM
nylyon's Avatar
nylyon
I wrote something up which may give you some insight on flushing.
Old Aug 22, 2011 | 01:18 PM
FKNVA's Avatar
FKNVA
That is correct. I was wrong
