Intermittent vibration
Old 08-16-2011, 09:31 PM
dyhrdford's Avatar
dyhrdford
dyhrdford is offline
This truck is driving me crazy lately! It is vibrating really bad, and making what sounds like a buzzing and maybe even a grinding noise. It seems like an injector, but it doesn't do it all the time, and it doesnt miss when I accelerate. Ambient/coolant temp, trans gear,, and road speed do not seem to make a difference. It seems that once I come off the freeway after about a half hour ride it the worst.
Hopefully someone can point me in the right direction.
Thanks.
Aaron
Old 08-17-2011, 05:37 AM
hammer65's Avatar
hammer65
hammer65 is offline
UVCH would be my first stop.
Old 08-17-2011, 10:23 AM
dyhrdford's Avatar
dyhrdford
What would be the odds that would be my problem if I already did the ford TSB to add the clips on the UVCH plug?
Old 08-17-2011, 11:28 AM
hammer65's Avatar
hammer65
hammer65 is offline
Dyhard: Someone on here posted the way to check them a vom. Do a search and you probably will find it, or someone will jump in here.
It seems that the plugs can get corroded or burned where it plugs into the Valve cover.
Also check wires for possible short to ground.
stydel311
02-17-2014 04:00 PM
cowmilker08
04-17-2010 09:46 PM
901
24
06-15-2008 04:55 PM
Ghoti
12-18-2006 08:03 AM
immaculate
Modular V10 (6.8l)
12-18-2003 08:10 PM
Quick Reply: Intermittent vibration
