Syncing Pictures
Old Aug 16, 2011 | 08:10 PM
basskicker's Avatar
basskicker
Syncing Pictures
I can't seem to upload pictures from a dvd or cd. I keep getting "bad or corrupted cd or dvd". Anyone else had a problem or even tried to do this.
Old Aug 16, 2011 | 08:32 PM
Painted Horse's Avatar
Painted Horse
Change the file format on your CD.
I'd have to go look it up, But most CD have more than one file format. The first time I tried to upload it didn't work, After reading the manual and changing the format that my PC wrote the file in, Everything worked fine.
Old Aug 16, 2011 | 08:40 PM
basskicker's Avatar
basskicker
How do you change the format the computer writes it in.
Old Aug 16, 2011 | 09:15 PM
Biggziff's Avatar
Biggziff
I think he's referring to formatting the CDRW before using it. You can only format rewritable CD media, not single use stuff. If you're using a RW disc, format it as FAT32 and see if that works for you. You also need to be sure that you have finalized or closed the session on the CD before trying to load it. Based on that info I'd recommend using non-rewritable media
Uploading pics to SYNC can be done and the pics can be viewed onscreen (of course otherwise what's the point?) and can be added to the home screen.
This information is detailed in the SYNC manual (page 23-24)
* You need to burn the pictures to a CD or DVD - the USB apparently won't do it.
* File size must be no larger than 1.5MB for each picture
* Make sure the CD or DVD has been finalized - it should not be pending to add more files.
* Load the CD or DVD into Microsoft SYNC and let it do its thing for a few seconds.
* Go to your main page where it shows the Ford logo. Touch the Ford logo.
* Press "add" to add the new pictures.
* You will see a screen pop up confirming you understand the requirements of the photos. If any of your pics on the disc do not meet this criteria they will not show up on the next screen. Touch "OK" and your pictures should show up on the list.
* You can select which pictures you want to add or select - you can press "add all"
* Your pics will appear on the right side and you can select a pic and delete it or edit it.
* If you press "Edit" you will be able to zom in and out, rotate and move up or down and more.
Here's a video that might help
http://www.youtube.com/watch?v=07ALOmH0NqE
Old Aug 16, 2011 | 09:26 PM
basskicker's Avatar
basskicker
Holy crap, that was a great reply. Thanks for the help.
Old Aug 16, 2011 | 09:27 PM
powerstroke72's Avatar
powerstroke72
I agree....outstanding post. Reps sent.
Old Aug 16, 2011 | 09:30 PM
Biggziff's Avatar
Biggziff
Thanks...I'm just good at cut and paste!
Old Aug 16, 2011 | 09:35 PM
EpicCowlick's Avatar
EpicCowlick
Ahhh... the power of the video! Great job.
Here's my home screen:
Old Aug 16, 2011 | 09:39 PM
Biggziff's Avatar
Biggziff
Like you'd know anything about that....
Old Aug 16, 2011 | 09:53 PM
basskicker's Avatar
basskicker
Ahhh. True Grit. John Wayne, Hmmmmm, wasn't he mostly directed by Ford(John Ford that is).
JReinert
6.7L Power Stroke Diesel
Oct 25, 2010 03:54 PM
51dueller
Mar 15, 2007 10:21 AM
fordborn
Chapter Meets Planning
16
Aug 15, 2005 04:36 PM
4tl8ford
53
Aug 7, 2003 07:51 PM
fatfenders
46
Jun 17, 2003 07:35 AM
