1986 ford f250 diesel trannmission problem
BOOST VALVE!!!!!!!!!!!!!!!
It tends to wear out and bypass fluid the stock one is a steel piston with an aluminum cylinder POOR design!!!
Install this entire kit 4L60E 700R4 4L80E 4R100 E4OD 2004R C6 TH350 TH400 Transmission Parts: SUPERIOR C6 SHIFT CORRECTION PACKAGE W/ BOOST VALVE
if it was rebuilt then take it back to them ! There are many different types of rebuilt trannys that come from different shops , some shops will clean the out side and paint it and charge you for a new one , some will only replace the seals and charge you for a new one , some will replace the worn parts with better looking used parts and tell you it is new ! there are lots of crooked tranny shops around !
Dbailey
03-22-2010 01:33 PM
