Air Bags
Old Aug 27, 2001 | 08:32 AM
ajs's Avatar
ajs
Air Bags
Old Nov 27, 2002 | 10:39 PM
TryMe's Avatar
TryMe
Air Bags
Hi Guys ! Have any of you ever install airbags on a early 90s Ford F-350 dually with I-beams ? If so what brand did you use ? Also how good do they work ? Thanks !
Old Nov 27, 2002 | 11:29 PM
slave2dafords's Avatar
slave2dafords
Air Bags
never installed have heard that they work good it is just too much work for me to deal with them i would try to upgrade the springs if you want more weight rating. now it is my turn to be duh you have coils correct or do you have leaf springs. (not thinking too well past midnight here lol)
Old Nov 28, 2002 | 12:57 PM
TryMe's Avatar
TryMe
Air Bags
Its a coil spring/I-beam truck. And the rear is leaf/shock.
Old Nov 28, 2002 | 01:43 PM
geevoor's Avatar
geevoor
Air Bags
i have a 97 f-250 hd that i use to haul a truckcamper with and i installed Timbren Rubber Springs they need no maintance and r easy to install.... best thing about these is once they r on just forget about them. u can find them here http://www.awdirect.com/awdirect/catalog.cfm?dest=itempg&itemid=7588&secid=73&linko n=subsection&linkid=215
or www.timbren.com
Old Nov 29, 2002 | 11:09 AM
slave2dafords
Air Bags
>here
>or www.timbren.com
the local spring shop talked to me about those i just could not remember the name of them. i just upgraded my f-150 coils recently put on rv 824 i have heard that the airbags are a pain in the rump for one reason you always have to ckeck the air pressure you dont want there to be none in them cause then they can get pinched and cut and you are out an airbag. i would look into larger springs or the timbrens replacing springs is easy if you want some pointers respond to the post or e-mail me slave2damud(No Email Addresses In Posts!)
Old Nov 30, 2002 | 11:51 AM
eddy13's Avatar
eddy13
Air Bags
I have firestone 2700 lb air bags on my 95 F250 and I'll never say a negative thing about them. I can't believe the ride and total lack of sway when they are pumped up. Mine are rated at 125 PSI but I haven't yet had them that high ( 65 - 70 maybe ). Installation is easy and when you don't need the overloads just release the air to about 10 PSI.
Brent
