400 4x4 Headers
Old Aug 13, 2011 | 06:54 PM
Thesteeleboy's Avatar
Thesteeleboy
Question 400 4x4 Headers
OK guys, who makes a good header for the 400 4x4 with an Automatic transmission. Must be inside the frame, clear the cross member, No frame notching required and will clear the starter without braking the bank. And while were at it, What do I do about my starter getting too hot due to the Header's. I sure could use your help with this little project. Thanks
Old Aug 13, 2011 | 09:29 PM
pintoches's Avatar
pintoches
I got a set of flow techs on my 79 400 no problems, $170! got them at O'Reillys
Old Aug 13, 2011 | 10:21 PM
Thesteeleboy
Headers
I also have A/C, Does your Bronco have an automatic, and did the headers go above the cross member or below it. Thanks for the help.
Old Aug 14, 2011 | 08:09 PM
NW 150's Avatar
NW 150
Flowtech 12520FLT - FlowTech Headers - Overview - SummitRacing.com
there ya go, cheapest set I can find. They'll fit, and use a heat wrap shield. Look one up at summit or a similar store.
Also that set will actually point directly at the crossmember, but they leave enough room to have the pipes either bent down and around/below the crossmember, or up and both go through the pass. side although it's hard to believe that.
Steve2916
Nov 2, 2012 05:03 PM
79Montanalariat
May 12, 2012 01:42 PM
kc5hwb
Dec 13, 2004 07:34 AM
78jpa
Nov 4, 2004 06:18 PM
eric77
Nov 25, 2002 11:20 AM
