my 2002 f250 truck is approaching 140k and im curious of the things i need to check on on my truck to make sure it is gonna stay with me for a long time to come.
New fuel filter (clean out bottom of fuel bowl while in there)
Clean your air filter
Change the oil
New brake fluid (bleed system)
Transmission service to include new fluid AND new in-pan filter
Radiator flush & new coolant, new t-stat, new t-stat housing (install a new coolant bypass filter system on your truck...worth it's weight in gold)
Change your rear differential fluid
Grease all your ball joints
I would install a larger transmission cooler while I was at it as that is as good as gold! And have a oil sample tested to look for other trouble spots like oil cooler, and high silica or iron levels. Adjust your steering box. Adjust your parking brake shoes. Lube your drive shaft slip yolk if equipped. Replace CAC bootsand clamps.
Jim...& fat Monty
