6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
White Smoke
Old Aug 13, 2011 | 08:38 AM
gwcon's Avatar
gwcon
White Smoke
Truck is running great other than my white smoke problem. The truck bucks a little and runs rough for a few seconds(as if it can't get the exhaust gases out) then white smoke pours out of the exhaust pipe. This happens only when I slow down(letting off the pedal) and then get back onto the pedal after about an hour long ride at highway speeds. It happens loaded and without a load. For example, getting off the highway and then taking off again at the end of the off ramp. After it finishes it's smoke fit the truck runs great again. Anyone experienced this problem or has any ideas what it could be? I talked with the service manager at my dealer and he mentioned something about an exhaust sensor.
Old Aug 13, 2011 | 08:58 AM
Tom's Avatar
Tom
Is it relatively humid when this happens? This appears to be a classic case of water accumulating in the CAC under low boost on the highway, then getting blown into the engine when you accelerate from a stop.
See HERE.
Old Aug 13, 2011 | 09:02 AM
gwcon's Avatar
gwcon
Tom,
Very humid here. Jacksonville, FL. It is happening to all my trucks so that could be it.
Old Aug 13, 2011 | 09:09 AM
Tom's Avatar
Tom
Sounds like it...
Fixed the link so you don't have to search through 5 pages! See HERE!
Old Aug 13, 2011 | 10:01 AM
gwcon's Avatar
gwcon
Tom,
Thank you for the information. Guess I will have to bring them in when I can. The only thing that doesn't fit that TSB is the fact that the 2010 is doing it also.
Mark
Old Aug 13, 2011 | 10:10 AM
Tom's Avatar
Tom
There have been some who have had their CAC replaced under the TSB and have still seen some white smoke. Most say that it's less than before having it replaced, apparently there's no good way to completely prevent water from accumulating in the CAC.
While I'm thinking of it, how's your coolant level on the affected trucks?
Old Aug 13, 2011 | 10:13 AM
bushman134's Avatar
bushman134
I have a 2010 and mine did it after sitting all night during rain storms and in FL humidity, DPF/CAT delete and tuned no more white smoke or problems
Old Aug 13, 2011 | 10:15 AM
gwcon's Avatar
gwcon
There all good. Never had a leak of any kind. I am a total stickler for maintenance and keep up with everything. I use a fuel additive at every fill up and the trucks all get worked hard.
Old Aug 13, 2011 | 10:31 AM
gwcon's Avatar
gwcon
bushman,
Would love to go DPF delete however, the warranty on the trucks is important to me.
Old Aug 13, 2011 | 11:23 AM
senix's Avatar
senix
You could just take the lower hose off of the cac and drain the water off till you get it in for a replacement.
I was down there the most of July for vacation...it is a humid place.
Old Aug 13, 2011 | 11:30 AM
gwcon's Avatar
gwcon
Scott,
It'll make you sweat for sure. I just might try that. Thanks.
Mark
Old Aug 13, 2011 | 12:20 PM
Tom's Avatar
Tom
This has been tried before and I haven't heard anyone have any success at preventing the white smoke.
Remember, the water doesn't form in the CAC when the truck sits, it happens when it runs. Then as soon as you see high boost it gets blown out of there, so the only way you're going to get a measurable amount of water out of there is if you have a long stretch with no boost and then stop the truck without hitting the accelerator pedal. And then all you're going to get out is what would have simply gone through the engine if you hit the pedal.
Draining before driving won't solve anything because it won't affect the water that builds up while cruising.
Old Aug 13, 2011 | 07:58 PM
Ronin 5729's Avatar
Ronin 5729
Hmmm...speaking-o-moisture, I was working on my buddy's '08 F350 today and we couldn't believe the amount of run-off we got we drained the CCV bypass catch can. While neither one of us has had the white smoke issue that's a whole lot of moisture that didn't have the chance to accumulate in the intercooler tract in the first place. It's been quite wet up from an accumulation and humidity standpoint too, but with our tuning and "driving style" there's usually ample occasion for higher boost levels anyway...
Old Aug 14, 2011 | 05:44 AM
gwcon's Avatar
gwcon
All of this information has forced me to ask the dumb question of the day, Is there nothing we can do about this? Is moisture accumulation just a fact of the 6.4? Can it be prevented by something other than tuning?
Old Aug 14, 2011 | 07:02 AM
Ronin 5729's Avatar
Ronin 5729
I'm pretty sure the CCV mod on my truck and my buddy's has something to do with not experiencing the issue. Some people upgraded their intercoolers (aFe, Spearco, etc.) which fixed the problem too and IIRC no one's had the problem with an upgraded intercooler...
