Which gear lube?
Old Aug 12, 2011 | 09:22 PM
turnkyle's Avatar
turnkyle
Which gear lube?
I have a 94 f150 that I want to flush the rear diff on and was wondering what gear oil to use. I am pretty sure I have the limited slip rear end so can I used 80-90 or do I need something lighter?
Old Aug 13, 2011 | 07:05 AM
Lazy K's Avatar
Lazy K
You will need something like 85W90 gear lube. If you do indeed have a LSD (check your door sticker axle code) you will also need a LSD additive unless you get the lube with it already mixed.
Old Aug 13, 2011 | 07:48 AM
IowanStraight6's Avatar
IowanStraight6
There's also a lot of us that switched over to 75w90 and 75w140 and if you want the best of both 75w90 with 20% Syn stabilized at least with Lucas but is there even another brand of lube on the market
Old Aug 13, 2011 | 08:58 AM
turnkyle's Avatar
turnkyle
Sounds good. Would a 75w90 be any better? I know a slightly lighter weight will give me less resistance, especially in the colder months, which is better for fuel mileage.
Old Aug 13, 2011 | 09:35 AM
turnkyle's Avatar
turnkyle
Axle code H9 pretty sure thats the LS
Old Aug 13, 2011 | 03:08 PM
IowanStraight6
It's a limited slip 3.55 ya I was gonna go with 75w140 in the rear but since I live in cold climate I called Lucas and they said 75w90 with the stabalizer is a happy medium and they said but I'd call and double check there Syn gear lubes already have friction modifier
Old Aug 13, 2011 | 10:21 PM
turnkyle's Avatar
turnkyle
Sounds good. I was thinking of going with the Mobil1 75w90, I am pretty sure it already has the friction modifier in it as well.
CTC01
Nov 19, 2014 11:44 AM
Louie3
1997 - 2003 F150
Feb 27, 2012 08:34 PM
YoungFordAddict66
Jul 10, 2010 12:13 AM
Dave85zxt
Aug 24, 2004 11:35 PM
Dave85zxt
Dec 31, 2003 09:56 AM
