Sounds like the return spring rubbing against something.
I agree.
Check under your dash and under the truck around the linkage area. If you need to, have someone else work the clutch while you are looking for the noise. From the sounds of it, it should be real easy to spot. Just sounds like the coil part of the spring catching on something near by.
