Still no buzz ...
Old Aug 10, 2011 | 08:28 PM
sullyt28's Avatar
sullyt28
Still no buzz ...
Have an '05 with a new motor. Key on the injectors won't buzz they just click (clack) away slowly. Result is the engine doesn't start great when cold. Truck runs excellent and starts good when warm. This isn't a problem now but will be come winter.
Here is what I've tried
- New batterys 1000 CCA - no change
- Rev X - no change
- Just installed new FICM (swamps 58V unit) - no change
- Oil change 15w40 rotella (no change)
There are no codes and I believe all the ground wires are good. The truck has the latest flash. Can't figure this one out.
Must be injectors but no smoke no rough idle and they were tested less than a year ago - one replaced.
Any ideas ??? Really worried if I take it in to the local dealer there not going to find anything and I'll be out more $$ !
Is there a buzz test that can be done to isolate injectors ??
Appreciate any help of suggestions.
Old Aug 10, 2011 | 08:52 PM
william_04_x's Avatar
william_04_x
Have you checked your FICM voltages yet?
There's a great write up at the top of the tech folder. Click..
Old Aug 10, 2011 | 11:57 PM
brickie's Avatar
brickie
If all else looks good pull the injector harness and check it for chafing,the tech folder has a post on prone chafe areas.
Old Aug 11, 2011 | 05:37 AM
sullyt28's Avatar
sullyt28
Did a little more investigation. Did Ford change the inductive flash from a buzz (high voltage arc'ng sound) to a lower voltage where the injectors (clack) and slowly ramps up ?
Why i think I had a problem is a buddy with an older 6.0 van has the loud buzz when K.O. - this van would not have the latest flash.
Any thoughts ?
Old Aug 11, 2011 | 06:36 AM
npccpartsman's Avatar
npccpartsman
Did your swamps FICM come preflashed or is it a Ford flash? I've heard trucks with the same "symptoms" you describe but I don't know what flash they had. On some the injectors start clicking slowly and ramp up. Mostly on later model trucks. An 04 I did yesterday with a "new" FICM and the latest flash buzzed the injectors very quickly from initial key on. None of them had problems starting.
Old Aug 11, 2011 | 10:45 AM
sullyt28's Avatar
sullyt28
It came pre-flashed which I assumed was the latest Ford Flash ? The FICM is actually from an '03 but with Swamps updates.
I was expecting it to 'buzz' like some of the videos on you tube etc. Its still doing is regular thing of 'clacking' which I'm told is normal ??
This flashing thing has me confused as my buddys van is an '04 - it buzz's with key on. Starts really well cold so I'm associating the lack of the loud buzz on my truck to be the issue. It may not ?
Keep in mind my truck starts okay. It does start better if I cycle the key twice when cold. When the weather gets colder it will start becoming more of an issue.
Old Aug 11, 2011 | 12:35 PM
dchamberlain's Avatar
dchamberlain
As I understand it, the original flash didn't buzz. Mine doesn't and it was last flashed Jan 2006, according to the Oasis.
As I understand it, the buzz flash came out to try to help with stiction. Then the first inductive heating flash that liked to kill FICM's, then the latest inductive heating flash. I don't believe the latest flash would buzz the injectors.
Old Aug 11, 2011 | 03:34 PM
sullyt28's Avatar
sullyt28
Called the local Ford dealer. Correct there was a TSB to change the induction to more of a rattle / clack than a buzz. Not sure why more people haven't noticed this ?
Be nice is one of the Techs chimed in to note the actual time (04 or 05 ?)and tsb.
jayc3169
Jan 18, 2015 12:51 PM
mkoser
Jun 10, 2012 09:03 AM
Johnny Be Cool
Modular V10 (6.8l)
Aug 22, 2010 11:38 AM
ibchris66
Jul 7, 2009 09:25 PM
