Warranty Issues
Also the A/C does not seem to cool properly some of the time, sometimes it feels humid in the cab as if running a swamp cooler. Anyone else have this issue?
When making a left turn I hear a low rumbling similiar to a bearing or hub issue, is this normal?
Last issue is the cooling fan has run for at least 20 minutes before shutting off when pulling travel trailer (outside temp was about 85 degrees). This has happened twice while towing but also empty on the way to work (25 miles) on a cold winter morning Have had this looked at but as is the norm it will not do it for the techs.
Also do i get the new flash or not? Are the issues worked out on the most recent one.
Thanks for any input, also I am not a troll, I love my truck and just want these few issues fixed on FoMoCo's dime and not mine.
https://www.ford-trucks.com/forums/5...ch-folder.html
As for the AC and the issues with your hubs, I'd take it in for the concerns. Maybe a different dealer is in order if yours is non response.
You should get the flash.
Also for your clutch fan...if is is sticking alot then they can test it but if they don't catch it I see why they would be reluctant to just change it out.
With their computer they can test it and see if it will come on and go off on command.
