Sway bar diffrences
Old Aug 10, 2011 | 03:09 AM
Jax Rhapsody's Avatar
Jax Rhapsody
Sway bar diffrences
I want to know if 250 and 350 had bigger sway bars than the 150's. I couldn't find anything in my search in this section. I wanted some bigger sways on my 88 Bronco. At least in the rear anyway. I figure my stock one in front with a 250 in rear, or a 250 front and 350 rear.
Old Aug 10, 2011 | 08:28 AM
Franklin2's Avatar
Franklin2
You will want to be careful messing around with the bars and changing sizes. You always want the front bar to be a lot larger than the rear.
1. Because all the weight is up front normally and
2. If you get the rear bar too stiff compared to the front, the rearend will slide around on you when it breaks loose.
Factory autos are designed to "push" into a turn. In other words if you take a curve too fast, the front will start sliding and going straight. They designed it this way because in this situation, most drivers will panic and hit the brakes, and this will quickly bring the vehicle under control. If you make the rear bar too stiff, it will make the vehicle "loose" and taking a turn too fast will make the rearend swing out instead. Recovering from that takes a little bit more fancier driving technique.
Old Aug 16, 2011 | 04:36 AM
Jax Rhapsody
I know and I read when you posted that somewhere else in my search. I just think it has a tad too much under steer.
Old Aug 16, 2011 | 04:49 AM
Archion's Avatar
Archion
Veteran: Marine Corps
It's a truck, it's not really meant to handle. With the weight bias of a truck you definitely do not want it too stiff in the rear. To put it simply, the only time a truck has equal weight distribution is when all four tires are in the air.
Old Aug 21, 2011 | 02:48 AM
Jax Rhapsody
I'm not too concerned with what it's meant to do. It's a Bronco not a truck, I want to make a lightning bronco so to speak. I'm going to drop it, put some wide tires under it, get it down to at least 5000lbs and have fun with it.
Old Aug 21, 2011 | 06:42 AM
Anafiel's Avatar
Anafiel
A Bronco IS a truck, and a rather fine one at that. Why don't you get yourself a Crown Vic or something like that and sell that 4x4 to someone that can use it?
Why ruin a perfectly good truck??
Old Sep 20, 2011 | 06:30 PM
Jax Rhapsody
It's an SUV and it's not ruining it. If I could sell it, I would. That way I could buy a crown vic. a friend of mine is selling one real cheap. If I can't sell it then project Bronco GT will comense. If I want a 4wd, Id get something without IFS. 4x4 purist won't change my mind.
Old Sep 20, 2011 | 08:48 PM
Anafiel's Avatar
Anafiel
Old Sep 28, 2011 | 12:34 PM
Jax Rhapsody
Originally Posted by Anafiel
jimmystoys
Apr 14, 2019 12:06 PM
corksil
Oct 4, 2015 02:15 PM
lslavick
Dec 26, 2005 10:52 AM
funkoptimus
Apr 8, 2005 03:50 PM
Charlie's Truck
Feb 18, 2003 09:34 PM
