Modular V10 (6.8l)
Leaking exhaust manifold E350
Old Aug 9, 2011 | 08:58 PM
SilverE350's Avatar
SilverE350
On behalf of my inlaws'...
Their 1997 E350 Class "C" has the rearmost top and bottom exhaust manifold studs on the passenger side broken off. There is a slight bit of soot on the gasket but no fumes getting into the cab. So my questions are:
1) Can this be left indefinitely until it gets worse?
2) Can I just pull the manifold and replace the gasket and broken studs with out replacing the manifold or other studs?
3) How big a job is it on a van?
Thanks.
Old Aug 16, 2011 | 09:55 PM
SilverE350's Avatar
SilverE350
Nothin? Nobody has any wisdom to impart?
Old Aug 17, 2011 | 05:52 AM
JWA's Avatar
JWA
The only wisdom I can share is maybe do a seach for "exhaust studs" in this forum------should be a lot to read about there. I did a quick search myself and recall a few threads with photos and learned experience about this somewhat common problem on the V-10's.
HTH
Old Aug 17, 2011 | 08:35 AM
Quad Racer's Avatar
Quad Racer
Yeah it's been talked about alot. If not here, try searching the super duty/heavy duty threads.
SilverE350
Aug 6, 2011 10:55 PM
kynnhoj
Modular V10 (6.8l)
May 6, 2005 02:23 PM
mobandy
May 31, 2004 12:28 PM
freeky1
Sep 19, 2002 01:21 PM
