straight six running hot?
Old Aug 9, 2011 | 04:07 PM
fordsuperduty250's Avatar
fordsuperduty250
hi i have a 1993 ford f150 xl with the 4.9l inline six. the other day i had a load of pallets in the back and i noticed that my temp gauge was still in the normal range but it was right at the high end of "normal". ever since that day the temp stays in the normal range but it runs hotter than it usually should. when i see the temp increasing i blast the heat for a bit and cruise in 5th to cool it down a bit. What could be causing this? Also i noticed that in my coolant resovoir it looks like it has overflowed a bit. any help would be greatly appreciated!
Old Aug 9, 2011 | 04:12 PM
6CylBill's Avatar
6CylBill
I'm going to su to this since mine runs hot too.
Old Aug 9, 2011 | 07:48 PM
str8sixman's Avatar
str8sixman
How's the coolant condition? Mine did that shortly after I bought it...po never serviced it and rad was plugged
Old Aug 9, 2011 | 08:33 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Might want to check your fan clutch...mine was acting weird-sometimes run hot, sometimes not. Didn't matter if I was loaded down, running A/C etc. I replaced the fan clutch and the temp gauge is rock-steady.
Roger
sullybear23
Jan 8, 2018 09:17 AM
Benchwrench
Aug 28, 2008 04:20 PM
shift1313
Aug 1, 2005 08:08 PM
proteks
17
Dec 14, 2004 12:35 PM
broncoray
21
Dec 12, 2003 03:47 PM
