351W Cam Timing Question
Old Aug 9, 2011 | 01:35 PM
ford_pickup's Avatar
ford_pickup
Hi all, I purchased a 351W HO from a 1984 F-150 and decided to go through and replace all gaskets, oil pump and pick-up, and the timing chain, I ended up getting a chain that has the three key-way timing choices and am not sure which to use, I thought that I had read that the cam came retarded from the factory to reduce emissions and then read otherwise the other day, SOOOO which way should I go, I am not trying to blast off to the moon, just as good of power as I can get for a bumpside and as good of gas mileage as I can muster, I bought a Holley 600 CFM for it too, any help is greatly appreciated
Old Aug 9, 2011 | 04:13 PM
Conanski's Avatar
Conanski
Put the cam in straight up or maybe advanced a couple degrees if anything for more TQ, the HO cam is an old marine grind which makes it a good overall performer.
Old Aug 9, 2011 | 04:47 PM
ford_pickup
So the keyway that's four degrees advanced is good?
Old Aug 10, 2011 | 08:00 AM
Conanski's Avatar
Conanski
Yeah that will work, just be aware it will shift the whole powerband down a few hundred rpms which is great for truck use but not so great if you want to build high rpm HP.
Gertrude351w
32
Aug 10, 2017 06:46 AM
craveman85
Jan 28, 2016 08:25 AM
pootscratch89
Dec 31, 2006 10:28 AM
78 Ranger
Apr 29, 2006 01:57 PM
