Sponsored by: Auxito
Spindle Questions
Old Aug 9, 2011 | 07:38 AM
BruceJeremy's Avatar
BruceJeremy
Spindle Questions
Hello. Ford-F250 (light duty). Just called the wreckers and they've got both a left and a right spindle. She asked if the truck was ABS and I said "no", although in retrospect I believe the truck does have an ABS. What's the difference?
Any help would be great.
Thanking you in advance!
Old Aug 9, 2011 | 08:03 AM
BruceJeremy
Ok, well 'ABS' is 'anti-lock braking system', correct? I'm pretty sure the truck in question does have it, so I'm out of luck with the no ABS ones??
"Pretty sure".....but where on-line can I double check the truck's specs, since my truck is at my garage, far, far away? I've got the VIN number, make and model.....I should be able to find out if the truck is equipped with an ABS, right??
Also, I'm wondering if the F-150 spindles will fit the light duty F-250? The balljoints I just replaced were F-150's, so by extension should the spindles be F-150's? I know the light duty F-250's have a different rear axle set-up.
I just don't want to be stuck with having to pay for parts that don't fit.
Help!
Turbotim2
May 21, 2009 09:39 AM
CampD
Apr 9, 2009 05:53 AM
cordespc
1997 - 2003 F150
Apr 14, 2007 11:29 AM
westladog
Oct 25, 2005 06:47 PM
