Tires
Old Aug 8, 2011 | 11:40 AM
rc70070's Avatar
rc70070
3rd Gear
Tires
Ive done my share of scanning on this forum and just cannot come up with a direct answer. My 2011 F250 FX4 came with 265/70 on 17" rims. On these stock rims what is the largest E load rating tire that i can fit without level or lifting? Thanks
Old Aug 8, 2011 | 09:04 PM
TxFordGuy1's Avatar
TxFordGuy1
I'm still on stock tires...but, just hit Discount Tire's site and see what it shows on the plus size. Probably a size or two up, but check the rating.
Old Aug 16, 2011 | 10:01 PM
FORDTUF1's Avatar
FORDTUF1
I have factory 20" rims and 285 tires so our number will be off quite a bit. Oh I yearn for the days when the tire company's would just tell you the darn height x width x rim size. They just had to muddy it up with aspect ratios.
Anyway, I have tires that are 35.4" tall and 11.8" wide. I can easily put 37" tall without leveling the front. Go to a good tire website and they will have the equivalent inch sizes next to all the aspect ratio tire sizes.
Old Aug 16, 2011 | 10:28 PM
fatheadon1's Avatar
fatheadon1
bfg at 315/70/17 will fit but rub the radius arm at full steering lock and you will lose a 1mpg or 2 depending on how you drive
Old Aug 17, 2011 | 10:21 AM
cummins cowboy's Avatar
cummins cowboy
my truck came with 17" wheels also and honestly I hate them, I think they look like steel wheels on the XL model. they really really look too plain to me. the generals on them are down to 3/32 tread after 16000 miles, for those that don't know tread depth that is 1/32 away from replacement. that is the worst tire I have ever had, to top it off. my truck had a pretty hard pull to the right, took it in for an alignment they adjusted it slightly. it still pulled bad, I rotated the tires and the pull went totally away. so one of the tires is causing the pull, I also ran a few general tires back in the mid to early 90's they were bad tires too, did I say generals suck.
what I plan to do is buy some used 18" wheels the ones that came on the lariet model, and run 275/70/18 BFG all terrains on them, this will change the appearance of the truck a ton, as it is the tires on there look puny.
Old Aug 17, 2011 | 09:40 PM
kper05's Avatar
kper05
Even the ContiTracs on my 18" wheels look too small to me.
I guess mine are lasting a bit longer than those Generals; of course still owned by Continental Tire.
Just waiting for the day I have a reasonable need to replace them.
I paid for these ContiTracs with the truck purchase so may as well use them.
Toplait
Nov 15, 2012 04:32 AM
fordman19762003
2004 - 2008 F150
Sep 3, 2008 04:14 PM
77mudder
Jun 23, 2005 03:07 PM
threetago
2004 - 2008 F150
31
May 22, 2004 01:26 AM
Jimmy Dean
Dec 4, 2003 06:58 AM
