No Vacuum
Old Aug 7, 2011 | 01:45 AM
Cracker289's Avatar
Cracker289
No Vacuum
I was setting my timing earlier and while messing with it I realized I could not feel any vacuum at the hose which connects to the distributor. I pulled the other end off the carb, and could not feel any vacuum there either.
What are some things that could cause this? The engine does idle, but very weakly. The carb is a motorcraft 2100.
Old Aug 7, 2011 | 08:34 AM
ilovemy60ford's Avatar
ilovemy60ford
The vacuum advance on the dizzy is usually connected to ported vacuum. A ported vacuum source will not have any vacuum at idle. It's likely normal.
Old Aug 7, 2011 | 08:55 AM
tmcalavy's Avatar
tmcalavy
Set your timing with the vac hose off the distributor and plugged. Then make sure the dwell (point gap) is good. Then set the curb idle speed, should be around 550 to 650 depending on whether it is a manual or auto tranny. Then connect a vacuum gauge or MityVac to manifold vacuum port...with truck running at idle you should get a steady 18 to 20 Hg of vacuum on the gauge. Adjust your carb mixture settings in or out to steady the vacuum reading on the gauge and get it in the 18-20 range. Then install the air cleaner and recheck/adjust the curb idle speed to get it around 550 to 650 rpm. Google "reading a vacuum gauge" for more info...too much to list here.
lvin4jc
27
Jan 2, 2017 05:10 PM
treverd
Jan 22, 2016 02:39 PM
daddy172005
May 29, 2009 06:15 AM
BigJonBear
Aug 29, 2007 07:54 AM
kking1977
Apr 26, 2003 04:31 AM
