no dash lights: help plz
Old Dec 2, 2002 | 05:56 PM
cryptonik420's Avatar
cryptonik420
Ok, I have an '87 F150. I checked the fuses that are for the interior lights and none of them are blown. I believe the positions for them were in the 4 and 5 spot on the fuse block. May I be missing something in the fuse box that would make the entire dash go out? I'm talking no light whatsoever except for the blinkers and the high beam light.
Thank you
Old Dec 2, 2002 | 06:25 PM
edenroadmaster's Avatar
edenroadmaster
if all the fuses check out ok, check the headlight switch. (make sure the dash light adjuster isnt turned all the way down) the contacts may be blown or coroded for the dash light dimmer.
eden
orange peel's Avatar
orange peel
