Fuel pump problems again.
Old Aug 3, 2011 | 04:38 PM
Alec94F150XL's Avatar
Alec94F150XL
Ok I have replaced the Fuel Pump (rear tank), fuel selector switch in the dash, fuel pump relay, and the 20 AMP Maxi fuse.
Also the ground/wiring is correct. Triple checked.
The front pump works fine, but the back won't come on.
Help!
Old Aug 3, 2011 | 04:59 PM
Slip ford man's Avatar
Slip ford man
You will need to verify that you have power back there when that pump is selected, you would jump pins 2 to 6, I believe on the test plug...be careful not to short out, maybe use a test light and a clean ground
Old Aug 3, 2011 | 05:22 PM
Alec94F150XL
I did the power test where it actually hooks up the fuel pump, no power, which is where I thought the selector switch had bad contacts for the rear.
So I'm at a loss?
BrianJoyner93
Dec 29, 2018 01:09 PM
RidersOnDaStorm
20
Oct 20, 2015 11:44 AM
Breaker Breaker 3-3
1983 - 2012 Ranger & B-Series
Jun 25, 2010 05:35 PM
Powerstroke-7.3
13
Dec 29, 2009 02:45 PM
mrcarter
Bronco II
Nov 17, 2004 11:58 PM
