a/c works and then doesnt...
Old Aug 3, 2011 | 03:50 PM
gcfisher75's Avatar
gcfisher75
Well with all this heat it is time to figure out my air conditioner.... when first turned on it works great, and sometimes will work for a while, but eventually it quits blowing cold and it gets humid in the truck, I checked charge with one of those cheapo deals that come w a can of charge, and it checks out good, I replaced my low pressure switch and still the same any one have a suggestion?
Old Aug 3, 2011 | 03:53 PM
guitarpicr's Avatar
guitarpicr
Is the clutch puulung in - Maybe its disengaging after running awhile- What are your pressures ?
Old Aug 3, 2011 | 03:58 PM
gcfisher75's Avatar
gcfisher75
The clutch does disengage, however I forgot to add if I shut it off after it quits blowing cold for say 2-3 minutes then it will work again for a short period of time.... my pressure I believe was around 30-35 according to the cheapo gauge...
Old Aug 3, 2011 | 04:17 PM
zx250's Avatar
zx250
Of the next Riffraff East
This fixed mine SpringerPop's Compressor Clutch Air Gap and many others here. Simple, 30min job.
Old Aug 3, 2011 | 04:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ahh you beat me to it. Was gonna post that
Old Aug 3, 2011 | 04:26 PM
zx250's Avatar
zx250
Yep, didn't know how badly mine was working until I got it working right.
Old Aug 3, 2011 | 04:51 PM
gcfisher75's Avatar
gcfisher75
Ah thanks! Looks like a likely culprit, and I love quick cheap fixes!
Old Aug 3, 2011 | 05:18 PM
zx250's Avatar
zx250
Mine only had one shim and was perfect when I removed it.
Old Aug 3, 2011 | 09:26 PM
CSIPSD's Avatar
CSIPSD
HOLY CRAP!!! Been playing with my AC for a few weeks... reading this thread and decided to check the air gap on my AC...
should be in the .020 range from what I am reading...
MINE........
.049! Over TWICE what it should be. Going to try and adjust it tomorrow.
Old Aug 3, 2011 | 09:29 PM
zx250's Avatar
zx250
I'm betting that will fix it. Mine was around .050 and wouldn't stay in when at idle.
Old Aug 3, 2011 | 09:39 PM
CSIPSD's Avatar
CSIPSD
Looks pretty easy on the write up, any concerns?
Old Aug 3, 2011 | 09:41 PM
gcfisher75's Avatar
gcfisher75
Yea seems if I kick mine down it'll come back, I bet this is the problem I will adjust it tmmrw.... I love this site... best tool ever!
Old Aug 3, 2011 | 09:43 PM
BigAlsPSD's Avatar
BigAlsPSD
Only takes about 5 minutes to remove the nut, throw away the spacer and reinstall, why wait! LOL
Old Aug 3, 2011 | 10:03 PM
zx250's Avatar
zx250
No concerns at all its easier than it looks.
Old Aug 3, 2011 | 10:33 PM
onelionhunter's Avatar
onelionhunter
Concerns
The only concern is after you do the mod, it will eventually wear down into the mounting studs and spark. I did the mod 2 years ago, two weeks ago, mine finally ran out of surface area and started to slip and spark a touch. Awesome mod, buys 2 years more time before you have to replace the clutch assembly, assembly was 120 through my local napa guy, no big deal. Highly recomend doing the reshim, and being as i bought mine used, it might have been the second reshim, I do not know.
