6.0 problems..help!
Old Apr 1, 2003 | 02:26 AM
F450man's Avatar
F450man
Exclamation 6.0 problems..help!
Hi
first time here...been reading on the new 6.0 and i have some priblems i need help with. 1st it seemed to shutter and miss and then seemed to have dead spot in pedal or throttle. dealer told me i got a new egr valve and crank position sensor. well dead spot still there and blew out 2 injectors and a turbo 100 miles later. a lot of oil came out of talpipe when loaded on the rollback, so ? is that amajor concern..help?
Old Apr 2, 2003 | 03:35 AM
The Diesel Dude's Avatar
The Diesel Dude
6.0 problems..help!
Check the oil to see if it is over the full mark. If it is, you've got fuel in it and one or more of your injectors has crapped out on you.
Old Apr 9, 2003 | 01:12 PM
RoyC's Avatar
RoyC
6.0 problems..help!
Joe,
I have read where some of the injector problems are associated with o-rings being cut/damaged upon installation, rather than just the injector itself failing. Can you give some insite to this?
RoyC
Old Apr 10, 2003 | 11:53 AM
The Diesel Dude
6.0 problems..help!
If you've got fuel in the oil, it is probably an internal problem with the injectors (an examination of the injectors will reveal wheather there is damage to the outside of the injector or the O-rings). If youe engine puked a lot of liquid out the turbo you risk having bent connecting rods. The only way to know for sure is to pull the engine. If I were you, I'd settle for nothing less than a new engine.
Johnny Bravo 45
Electrical Systems/Wiring
Jul 11, 2024 06:17 PM
Fully_Loaded
Computer Chips & Tuners
Oct 25, 2006 08:23 PM
Troy G
Sep 6, 2005 06:17 AM
