fuel pressure for my 460
Old Feb 16, 2023 | 09:06 AM
allen360's Avatar
allen360
3rd Gear
The guy you’re asking hasn’t been back since that Aug 2020 post. The possible causes were given in post #11. Do you have dual tanks? If so, is the pressure low on both on them or only on one tank?
hello, I have the 7.5l v8 box truck e350 94… it has a single tank the previous owner replaced the fuel injectors fuel filter. I’ve replaced spark plug, wires, distributor. Ignition coil. Mass air flow sensor. I check the pressure on the fuel rail getting 32- 38? At an idol.and start. It won’t go over 25-15mph going up hills back fire. Struggles to make it back to the shop. Jolts of power…You have to tap the gas to get a jolt of energy… it will idle for hours fine and sound perfect, strong. But the second I drive up a hill it loses all power struggles. Even going down a hill it would lose power over 40mph. when I press the gas. You can’t hear the exhaust leak, no power, kills the engine after a bit… every time I tow it to the shop (after it will no longer start or drive for me) it starts right up for shops. (I’ve had to tow it twice) they drive it fine and it idols in the parking lot for hours fine.. I have videos but they are a couple mins and to large to upload. Hopefully that all helps and made since. Thanks. We’re going to look more into/ replace the fuel pump today. But after that we have no idea.
Old Feb 16, 2023 | 09:26 AM
allen360's Avatar
allen360
3rd Gear
it doesn’t cause a check engine light plus it obd1
Old Feb 16, 2023 | 10:21 AM
Prototypemech's Avatar
Prototypemech
You'll have more success getting your questions answered if you make your own thread, vs piggy backing on a 3 year old thread. It helps keep the forum clean and easily readable.
Diesel_Brad
100
Jun 12, 2018 05:36 AM
Mattmason
Jul 25, 2015 09:19 PM
Steam
Aug 26, 2004 07:38 PM
kevinrf250
Oct 15, 2003 11:06 PM
