Operation: Zebra build
#1156
#1157
#1159
Well its a 302 Fuel Injected intake manifold. I practically stole it as it cost the guy more to ship then I bought it for.
Yeah there are 2 problem areas that worry me on the Zebra.
1. The rear quarter panel is actually broken through to the inside of the vehicle. Anything short of a panel replacement is gonna be cutting corners
2. The A pillar may be damaged. i can't tell without pulling the door and fender, but the shattered windshield makes me think its been bent/tweaked.
Those two areas require alot of time/money to fix. Might be best to salvage what I can and bring another old Ford back to its Glory days.
#1161
#1162
Received 5,209 Likes
on
#1164
#1165
on
#1166
#1167
Ok well I have begun taking broken pieces off. The entire headlight assembly on the pass side is toast, the core support is twisted like a pretzel.
The entire HVAC assembly is destroyed, the jack and tire wrench were actually where the blower wheel should be.
http://www.flickr.com/photos/62639173@N03/8450496829/http://www.flickr.com/photos/62639173@N03/8450496829/ by http://www.flickr.com/people/62639173@N03/, on Flickr
The fender is actually pushed back behind the door and into the cab!!
http://www.flickr.com/photos/62639173@N03/8451593152/http://www.flickr.com/photos/62639173@N03/8451593152/ by http://www.flickr.com/people/62639173@N03/, on Flickr
#1168
OK, well most all of the broken stuff is out. Basically everything on the passenrger side of the motor is gone. I am going to have to cut the fender in half for now. I am going to try and fab up a bar as a support in lieu of the fender and try to bolt the battery tray to it so I can at least move the truck around for the time being. I completely removed the HVAC assembly (pieces) and tucked the wiring harness into one of the holes where the blower was in the firewall. I need to get a cover for that area.
http://www.flickr.com/photos/62639173@N03/8450596455/http://www.flickr.com/photos/62639173@N03/8450596455/ by http://www.flickr.com/people/62639173@N03/, on Flickr
#1169
#1170
