injectors
Old Jul 30, 2011 | 04:02 PM
49 Ford F-1's Avatar
49 Ford F-1
injectors
what are some good brands of stage 1 injector? I'm looking to have a little more power and increase my mpg. Thank you.
Old Jul 30, 2011 | 04:14 PM
Stewart_H's Avatar
Stewart_H
Brand new AC code injectors is the way I went.
When it comes to turbo's and injectors, I just prefer brand new and not remanned, that's why I went with the AC's.
Transmissions (John Wood) and HPOP's (Joey at Terminator Engineering) I don't mind being rebuilt, but I really prefer new when it comes to injectors.
Stewart
Old Jul 30, 2011 | 04:17 PM
49 Ford F-1
yea I'm looking for new stage ones.
Old Jul 30, 2011 | 04:19 PM
Stewart_H's Avatar
Stewart_H
I'd just get a set of AC codes then.
I think Clay sells brand new AC codes.
Stewart
Old Jul 30, 2011 | 04:26 PM
49 Ford F-1
AC codes? what are they? where can I look at at clays stuff?
Old Jul 30, 2011 | 04:41 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
got mine from swamps with a 2 year warranty. dont get 2 years on the new ones.......
oh and i love them and you will love yours as well....
Old Jul 30, 2011 | 05:40 PM
Terryw5782's Avatar
Terryw5782
Here on Clay's site:
Riffraff Diesel: New Alliant Stock Injectors
Old Jul 30, 2011 | 05:49 PM
CSIPSD's Avatar
CSIPSD
Installed a set of NEW AC's (160cc with stock nozzles) on Chelseas Excursion a few months ago, very nice and a solid 350hp injector. With some 100% nozzles they would hit very close to 400hp.
Old Jul 30, 2011 | 05:50 PM
49 Ford F-1
what is the difference in the AC and stage one injectors? From what I have seen there is a lot of debate on this issue some say they are same as stage 1s, and other say same as stock. I have seen where someone showed they are only 150 (i think) compared to the 165 of stage 1 injectors.
Old Jul 30, 2011 | 05:57 PM
CSIPSD's Avatar
CSIPSD
It depends on who is building them...
AC's come in the high output versions of the 444. They are a single shot 160cc with stock nozzles. They are not built with someone's cores, they are new (assuming you buy NEW) built injectors directly from Alliant.
"Stage 1's" from most builders are also a 160cc injector with a stock nozzle. However they are built with CORE injectors that are sent back to them. Will there be a problem, more then likely not, but you never know.
There is no set in stone "stage 1, stage 2 and so on."
Ask what CC and what nozzle size when you are buying injectors. Otherwise you know nothing.
Old Jul 30, 2011 | 06:00 PM
CSIPSD's Avatar
CSIPSD
Writen by a good friend of mine...
Larger nozzles- By installing larger nozzles you are makeing the nozzles less restrictive so that more fuel will flow out of them with everything else being the same. Stock injectors with stock programming and larger nozzles will get more fuel out and make more power. Stock injectors only modified to have more fuel capacity with stock nozzles and stock programing will run exactly like stock injectors. In this case the only way to get more fuel out is with a chip to extend the open time of the injector and/or increase the Injection Control Pressure (ICP) to push more fuel out the nozzle. On the same note if you say make a hybrid (installing a larger 7mm plunger and barrel out of a DT466/I530E injector) and leaving the intensifier piston the same will effectively reduce your injection pressure. This less injection pressure will make less pressure at the nozzle and will actually flow less fuel with a stock nozzle than a bone stock injector. So to get the fuel out without a chip you would need larger nozzles.
There is also a point where the stock nozzle just wont flow enough fuel to get the desired amount out in a realisitic time frame. That's why high capacity injectors require larger nozzles to use that capacity.
Codes- All powerstroke and T444Es come with A code injectors. A code injectors have a 6.0mm plunger and a 16mm intensifier piston. What this does is multiply the ICP so that injection pressure is adiquate but not having to have huge amounts of ICP like say in the 20,000 psi range. This difference give you approximately a 7:1 difference and therefore increases your injection pressure 7 psi for every 1 psi of ICP.
All DT466s and I530E injectors are B codes. Of those some DT466s and all I530Es have a 7.1mm plunger, hense more fuel per mm of stroke, with a 17.5mm intensifier piston. This gives you approximately a 6:1 ratio. So no it will not have quite as high of ICP as as the A codes but it's not as bad as it could be. However due to the larger intensifier piston they reqire much more high pressure oil to make the piston stroke the same distance. This is why you need a high pressure oil system with a higher capacity.
Hybrid injectors are taking the 7.1mm plunger and barrel out of a BD code I530E injector and installing it into an A code injector with a 16mm intensifier piston. As you could imagine the down fall is that the injection ratio is dropped to approximatly 5:1 further decreasing injection pressure. However with the smaller intensifier piston it requires no more oil than an equivilant A code yet it flows the same amount of fuel as a B code. The result is much more fuel capacity without the need for more high pressure oil volume.
A codes and B codes can be further broken down as well.
A and AA injectors came in the '94-'97 non-california trucks. They are all 90cc injectors and are single shots.
AB injectors came in the '97 cali, and all early '99 trucks. They are split shot injectors meaning they fire a small pilot shot before the main shot. These injectors flow 130-135cc of fuel.
AC injectors are found in the high torque version of the T444E and do not come in any Powerstrokes. They have the same internals as the AB injectors with the exception of the single shot plunger and barrel. However due to them being single shot injectors they flow 160cc. This is due to the way the split shots work. They have a small passage that opens, much like a port in a two stroke engine, that are uncovered that bypass the injection pressure out the side of the barrel instead of out the end through the nozzle. Because of this pause a portion of the travel of the plunger does nothing for injecting fuel so a split shot injects less fuel for the same amount of travel as a single shot.
AD injectors are also split shot but flow 135-140cc of fuel due to a slightly longer plunger stroke. These are found in all late '99-'03 Powerstrokes and T444Es.
AE and AF injectors are essentially the same as AD injectors but were called a long lead injector that was used as an attempt to cure a "cackle" issue many people complained about.
BA, BB, and BC injectors are essentiall all the same and are the same as AC injectors but are found in some DT466s.
BD injectors are the only B codes with the larger 7.1mm plunger and barrel that are single shot injectors. These are the injectors people are usually talking about when they are talking about putting I530E injectors in their Powerstrokes.
BE injectors are essentially the same as the AD injectors but found in some '97-'99 DT466s.
EF, BG, BI, BJ, BN and BP injectors all have basicly the same capacity and are split shots. However the nozzles vary on them depending on application. They can be found in many DT466s and I530Es.
-GTS "hotwheels"
Old Jul 30, 2011 | 06:11 PM
49 Ford F-1
ok this is great information. So my 99 is a early so I have AB injectors. What type of fuel millage increase and power (with supporting mods) could I see with these injectors? Also is it $212 for all 8 injectors or single ones?
Old Jul 30, 2011 | 06:26 PM
CSIPSD's Avatar
CSIPSD
Right now you would dyno 300hp give or take...
With the AC's and a healthy HPOP you will be very close to 340...
Mileage might increase a bit, but dont count on it.
Old Jul 30, 2011 | 06:29 PM
49 Ford F-1
hey is that $212 from Riffraff diesel per injector?
Old Jul 30, 2011 | 06:38 PM
CSIPSD's Avatar
CSIPSD
Sounds about right...
I paid $1500 for mine, but I got a rather smoking deal.
