Rewiring the 6 volt '51 F4
i just converted my front running lights into running/directionals, and my rear to running: brake/signal. i used a 7 wire switch and the brake and directional share the same filament in the back (with running lights on the other filament), that's why the brake wire goes from the brake switch through the directional switch, then two separate wires from directional switch to rear lights. the wiring diagram was clear about all this and its working fine. dick r.
I made my own wiring harness, keeping my '53 as 6v positive ground. I disconnected wires at their destination, labeled them at the connection with masking tape, and basically removed the entire harness as one large piece of spaghetti still connected to the back of the speedo/dash and switches assembly. gently pulled the whole mess into the cab thru the big ol firewall grommet hole. It looked much more disconcerting laid out on the floor of the garage than it actually was to work with. Then I just replaced each wire one at a time length for length, end for end until everything was new. I soldered and shrink tubed everything, labeling the new to match the old as I went. I used twist ties to hold the whole mess together until after it was reinstalled into the truck, feeding it all back thru the firewall grommet hole. Then as time goes by, and things get arranged, don't get changed or redone, I'll zip strip what's completely finished replacing the twist ties. One rule of thumb for wire sizes, step up one gauge (ie: 12g to 10g) from what would be normal 12v wiring to use 6v. you have half the voltage, so you need twice the amperage, hense the next size heavier wire. Other than the battery and starter cables, the wiring for the generator and battery are 10gauge. I used a simple off the shelf 8 space fuse block from NAPA along with the original circuit breakers on the back of the speedo.
My turn signals are the simple 3 wire switch assembly in the top of the steering column. As I understand it, it was an option at the time, and I have to run separate turn signal wires and lights front and rear. No big deal, they just got twist-tied into the harness lol. Cheap booger that I am i used some motorcycle turn signals that were laying about, and reworked the big round knobber lights added onto the front fenders. Ive seen the switches, and canceling assembly listed on E-Bay from time to time. I still only have one brake/tail light in back on the left, but will get around to adding one to the right one of these fine days. BTW, your brake light switch is probably at the tail end of your brake master cylinder and pressure operated. The stop light wire in mine ran down to the switch, then the rest of the way back to the tail light assembly. If you do the fancy all in one brake/tail/turn set up you'll need to run your brake switch wire down to the MC then back up to the turn signal switch assy.
Assume nothing. The truck will run either way but it will run better if the coil is electrically correctly hooked up. That is why the little + and - is marked on the coil. It is an effeciency thing. Just follow the schematic when you rewire it.
OK thanks. I don't have taillights yet, but I know the bulbs for them need to be dual filament for brakes/taillights. I was planning to use the brake filament for turn signals.
Is there a way to determine before purchasing the turn signal switch which of the different types of switch it is?
Here is a pic of mine:
Does anyone know if this chrome universal turn signal switch from LMC Truck is a 7-wire switch? It sure looks like a Signal Stat in the picture. Part number 48-4905. That looks like a good price at $25.
LMC Truck Parts - Page 59
'51 6cyl wiring specs
I used several resources to compile a list of the wires in my truck. They are listed by AWG and color, as well as to and from destinations. No turn signal wiring is shown, as I don't have them in my truck yet. And the wiring for the electric wiper motor and switch are not shown, as they are not in any of my reference materials other than a picture in the Shop Manual. Now I need to figure out how much wire to buy of each of the 25 colors/stripes. I think I'll stick to the basic Yellow, Red, Green, Black, Blue wire and if I can find it, add shrink tube at the ends to indicate the stripes in Black, Yellow, Red, Orange, Green, White and Blue.
1951 Ford 6 Cylinder Wiring Harness
10 Gauge (Yellow)
Starter Switch to Ammeter
Ammeter to Circuit Breaker 1A
Circuit Breaker 1A to Voltage Regulator BAT
10 Gauge (Yellow –Black Stripe)
Voltage Regulator A to Generator A
12 Gauge (Red – Yellow Stripe)
Light Switch H to Dimmer Switch
12 Gauge (Green – Black Stripe)
Dimmer Switch to Headlight High Beams
12 Gauge (Black – Red Stripe)
Generator G to Voltage Regulator Ground
14 Gauge (Yellow)
Circuit Breaker 2A to Ignition Switch AM
14 Gauge (Yellow - Red Stripe)
Circuit Breaker 1B to Light Switch left center
14 Gauge (Red – Black Stripe)
Dimmer Switch to Headlight Low Beams
14 Gauge (Black)
Headlights to Ground
Coil (+) to Distributor
Dome Light to Ground
14 Gauge (Black – Orange Stripe)
Circuit Breaker 2B to Light Switch right front
16 Gauge (Red) 39 feet on spool
Starter Switch to Starter Button
16 Gauge (Red – Green Stripe)
Ignition Switch COIL to Coil (-)
16 Gauge (Red – White Stripe)
Temperature Sender to Temperature Gauge
16 Gauge (White - Red Stripe)
Oil PSI Engine Unit to Oil PSI Gauge
16 Gauge (Yellow)
Gas Tank Sender to Gas Gauge
16 Gauge (Yellow – Green Stripe)
Starter Switch to Horn Relay
Horn Relay to Right Horn
Right Horn to Left Horn
16 Gauge (Black)
Light Switch to Left Taillight
Left Taillight to License Plate Light
Left Taillight to Right Taillight
16 Gauge (Black – Yellow Stripe)
Light Switch to Parking Lights
Horn Button to Horn Relay
16 Gauge (Blue – Red Stripe)
Instrument Light Switch to Instrument Lights
16 Gauge (Black – Blue Stripe)
Circuit Breaker 1B to Dome Light Switch
Circuit Breaker 1B to Door Light Switches
16 Gauge (Black – Green Stripe)
Ignition Switch GA to Gauges
16 Gauge (Green)
Circuit Breaker 1B to Stop Light Switch
Stop Light Switch to Stop Lights (or to Signal Stat 900 T/S Switch)
16 Gauge (Green – Black Stripe)
Dimmer Switch to Beam Indicator Light
16 Gauge (Black – White Stripe)
Generator F to Voltage Regulator F
16 Gauge (Green – Yellow Stripe)
Door Light Switches to Dome Light
10 Gauge (Yellow)
14 Gauge (Yellow)
14 Gauge (Black)
16 Gauge (Yellow)
16 Gauge (Black)
16 Gauge (Green)
Thanks. I tried that after putting it into a Word table, but it comes out as seen above. Hopefully it's understandable. It's not formatted correctly...
<TABLE style="WIDTH: 401pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=535 x:str><COLGROUP><COL style="WIDTH: 132pt; mso-width-source: userset; mso-width-alt: 6436" width=176><COL style="WIDTH: 269pt; mso-width-source: userset; mso-width-alt: 13129" width=359><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 401pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl24 height=17 width=535 colSpan=2>1951 Ford 6 Cylinder Wiring Harness
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl24 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl24></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>10 Gauge
(Yellow)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Starter Switch to Ammeter</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Ammeter to Circuit Breaker 1A</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 1A to Voltage Regulator BAT</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 38.25pt" height=51><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 38.25pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=51 width=176>10 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Voltage Regulator A to Generator A</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>12 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Light Switch H to Dimmer Switch</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>12 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Dimmer Switch to Headlight High Beams</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>12 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Generator G to Voltage Regulator Ground</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>14 Gauge
(Yellow)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 2A to Ignition Switch AM</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>14 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 1B to Light Switch left center</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>14 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Dimmer Switch to Headlight Low Beams</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>14 Gauge
(Black)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Headlights to Ground</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Coil (+) to Distributor</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Dome Light to Ground</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 38.25pt" height=51><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 38.25pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=51 width=176>14 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 2B to Light Switch right front</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Starter Switch to Starter Button</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Ignition Switch COIL to Coil (-)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Temperature Sender to Temperature Gauge</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Oil PSI Engine Unit to Oil PSI Gauge</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
(Yellow)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Gas Tank Sender to Gas Gauge</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Starter Switch to Horn Relay</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Horn Relay to Right Horn</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Right Horn to Left Horn</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
(Black)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Light Switch to Left Taillight</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Left Taillight to License Plate Light</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Left Taillight to Right Taillight</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Light Switch to Parking Lights</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Horn Button to Horn Relay</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
(Blue – Red Stripe)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Instrument Light Switch to Instrument Lights</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 1B to Dome Light Switch</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 1B to Door Light Switches</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Ignition Switch GA to Gauges</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
(Green)
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Circuit Breaker 1B to Stop Light Switch</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=34 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Stop Light Switch to Stop Lights (or to Signal Stat 900 T/S Switch)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Dimmer Switch to Beam Indicator Light</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Generator F to Voltage Regulator F</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 height=17 width=176></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl23 width=359></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 132pt; HEIGHT: 25.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 height=34 width=176>16 Gauge
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 269pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl22 width=359>Door Light Switches to Dome Light
</TD></TR></TBODY></TABLE>
(Yellow)
(Yellow)
(Black)
(Yellow)
(Black)
(Blue – Red Stripe)
(Green)
And I don't want to do that until I have it idling correctly; it won't idle, runs rough at lower RPM and stalls. I just ordered a carb rebuild kit. The mixing screw makes no difference so I'm hoping that's all it needs.
#30
Colors should be the same, but lengths will be different between the 6 and 8, and between 48-50 and 51-52. For instance the generator is further from the regulator on a 6, and the dashboard wiring will be different between 48-50 and 51-52.
Actually the '52 with a 6 (OHV) will be different than the '51 with a 6 (flathead), too.
