Sponsored by: Real Truck
Ubolt nuts???
Old Jul 29, 2011 | 08:45 AM
sportsdad's Avatar
sportsdad
Ubolt nuts???
I've searched my **** off and not found the answer. It seems obvious, but I'll put it to you guys. I'm getting ready to put on new x-codes. Ordered everything yesterday, but did not order ubolt nuts. Question is, new nuts or not?
Old Jul 29, 2011 | 09:30 AM
lakedweller's Avatar
lakedweller
I would replace both....
Old Jul 29, 2011 | 09:39 AM
BigPigDaddy's Avatar
BigPigDaddy
Everyone says to replace the U-bolts because they are Torque to Yield or something fancy like that. As far as I know, nuts are nuts so it doesn't matter. However, I believe the factory thread pitch is different (metric?) so the old nuts probably won't work on new U-bolts unless they are all from Ford. Out of curiosity, where are you getting U-bolts that don't include nuts?
Old Jul 29, 2011 | 10:06 AM
sportsdad's Avatar
sportsdad
FORD stealership. So my old nuts should fit.
Old Jul 29, 2011 | 10:12 AM
BigPigDaddy
I should have guessed that Ford would not include nuts. I guess that means that they think you don't need to replace them either.
Old Jul 29, 2011 | 11:50 AM
sportsdad's Avatar
sportsdad
You are kinder than I. My experience says they think you need to buy all seperatly for more $.
Old Jul 29, 2011 | 12:37 PM
Emustang04's Avatar
Emustang04
I would replace them, better than doing it twice for the wrong reason.
Old Jul 29, 2011 | 12:38 PM
BigPigDaddy
I was trying to be nice.
You could always ask the parts guy to throw 'em in for free.
Old Jul 29, 2011 | 02:48 PM
Persona's Avatar
Persona
The U-bolt nuts are not TTY, there's no mating surface contact which would necessitate it. Just torque to whatever spec they give and re-check a couple of times after putting a few miles on...I check after a test drive, then again a few days later to make sure they are tight.
Old Jul 29, 2011 | 03:46 PM
sportsdad's Avatar
sportsdad
Persona, I don't doubt you about the ubolts, but you can find vast amounts of info on how these things are TTY. So, not to be a jerk, but why should we/I believe you?
Old Jul 29, 2011 | 04:00 PM
BigPigDaddy
Actually, he said the u-bolt nuts aren't TTY.
Old Jul 29, 2011 | 04:30 PM
sportsdad's Avatar
sportsdad
I faintly remember my english teacher telling my to pay better attention to what I read. Persona, my most humble apologies. BPD, thanks man. Looks like I'm not gonna order any new nuts.
Old Jul 29, 2011 | 04:33 PM
sportsdad's Avatar
sportsdad
Just for conversation, I've delt with several TTY applications in my farm equipment over the years, but never in a nut and bolt application. Head bolts come to mind as the most common application. Whats with TTY bolts on an axle?
Old Jul 29, 2011 | 08:38 PM
tawells01's Avatar
tawells01
My two cents--
Fastener elongation generates a compressive load on the nut threads which can cause thread deformation. Thus, the reused nut will likely require an increased torque value to reach the clamp load needed.
Additionally, nut threads will conform to the shape of the bolt threads when tightened. Reuse with a new bolt would no longer give a thread match. Friction won't be the same if the old nut is used with the new bolts and installation torque will be altered.
Old Jul 29, 2011 | 08:59 PM
BigPigDaddy
Originally Posted by tawells01
My two cents--
My head hurts after reading that.
How appropriate that you would have a quote from Einstein in your signature.
