Remove rear blocks?
Old Jul 28, 2011 | 07:14 PM
jazz77's Avatar
jazz77
Remove rear blocks?
Say if I wanted to remove the rear blocks on my ex and go all springs what would I need so that it would match the V or X front. Is it even possible?
Old Jul 28, 2011 | 07:42 PM
ocboat's Avatar
ocboat
I installed the Pro Comp 22415 without the block in the rear to go with V codes up front. This leaves about my Ex about 1.75" high in the back. X codes would match better or an addition of a small lift hanger or mini pack to go along with the V codes in front which is what I am going to do.
Old Jul 28, 2011 | 08:17 PM
jazz77's Avatar
jazz77
Thanks. Maybe I will go with X springs as I am planning on a cummins swap next spring.
Old Jul 28, 2011 | 09:00 PM
ocboat's Avatar
ocboat
If you don't already have the front springs you could match the Pro Comp 22415 rears with the Pro Comp 22210 fronts. There are several members with this combo and it a a fairly inexpensive way to upgrade all four springs and get about 4" of lift.
Old Jul 28, 2011 | 09:06 PM
jazz77's Avatar
jazz77
Hmm...not really interested in much of a lift but I wonder what that will settle at with the xtra weight of the cummins and possibly ranchhand bumper? Basicly looking to clear 305s a
Old Jul 28, 2011 | 10:49 PM
BigPigDaddy's Avatar
BigPigDaddy
I clear 305's with V codes and a 2" mini-spring pack (total of ~3") on my F250. I don't think it would be enough with a cummins and ranch hand bumper. I think the 4" lift springs would be just right for you.
Old Jul 28, 2011 | 11:58 PM
jazz77's Avatar
jazz77
Ok sounds like that's the direction I'm heading. Thanks for all the advice
etdavenport
Jun 25, 2016 11:58 PM
Shepherd2
Jan 27, 2016 02:24 PM
Xcursion88
Jun 6, 2014 11:47 AM
Turingmachine
May 17, 2011 10:48 PM
02superstroker
Aug 25, 2003 12:43 AM
