t-stat direction
Old Jul 28, 2011 | 01:32 PM
blue10554's Avatar
blue10554
t-stat direction
I am replacing the t-stat in my 06 ford f350 and am curious if there is a certain direction that it needs to be installed?
Old Jul 28, 2011 | 01:45 PM
davidkstyler's Avatar
davidkstyler
Don't they usually come installed in the housing?
Old Jul 28, 2011 | 01:52 PM
npccpartsman's Avatar
npccpartsman
You can't put it in wrong. It comes already in the housing and only fits one way.
Old Jul 28, 2011 | 02:18 PM
69cj's Avatar
69cj
That's a pretty bold statement Tim. I think I've seen one or two on here that could manage it. LOL
Old Jul 28, 2011 | 02:30 PM
blue10554's Avatar
blue10554
Thanks, I have the housing and the t-stat as one piece but I just noticed that there is a little dot that sticks out a little and just wanted to make sure it doesn't
have to go a certain direction. It will go in both ways so I was just curious.
Old Jul 28, 2011 | 02:34 PM
davidkstyler
Make sure it matches the one you are taking off and you should be fine.
By the way, welcome to the forum! Take a look in the Tech Folder there is a huge amount of useful information hidden in there.
Old Jul 28, 2011 | 02:40 PM
blue10554's Avatar
blue10554
It matches, I just didn't take notice which direction the old one came out.
Old Jul 28, 2011 | 04:26 PM
davidkstyler
IIRC the housing outlet points straight up so rotation should not matter. Is that what you were asking about?
Old Jul 28, 2011 | 05:19 PM
69cj's Avatar
69cj
There is a small bleeder hole to get all the air out of the system. Make sure that is on top or up.
Old Jul 28, 2011 | 05:32 PM
bpounds's Avatar
bpounds
It cannot go the wrong way, because the bolt holes are not on the centerline.
Old Jul 28, 2011 | 05:42 PM
69cj's Avatar
69cj
Bill, correct me if I'm wrong, I'm going by memory. If you remove the t-stat, from the housing, for a flush it can be loaded into the housing wrong and the bleeder can in fact be 180 degrees out.
Old Jul 28, 2011 | 05:54 PM
bpounds's Avatar
bpounds
You mean, like inverted upside down? I don't think it can.
If you mean rotate it 180°, yes I think it can, and I don't think it would matter if you did. The vent would still work.
Here is the thread where I originally posted those pics. There are some more pics that might help.
https://www.ford-trucks.com/forums/9...with-pics.html
Old Jul 28, 2011 | 05:58 PM
69cj's Avatar
69cj
This is what I meant and yes the vent would be 180 degrees from the way it was taken out originally. I can't say it would or wouldn't make a diff. I would rather not take the chance of trapped air that I couldn't get out. It was on the top when removed and that's where I felt it should go back in.
Old Jul 28, 2011 | 06:02 PM
BLADE35's Avatar
BLADE35
I dont think it matters the vent/bleeder location just cant be clogged with junk
for the op just have to twist and push the tabs
Old Jul 28, 2011 | 06:04 PM
bpounds's Avatar
bpounds
I agree, better be safe than sorry. The purpose of the vent I believe is to make sure air can pass through, so that the thermostat gets wet. It would never open if in a trapped air bubble.
