Running extremely choppy!
Old Jul 28, 2011 | 01:09 AM
decscorpion's Avatar
decscorpion
I have a 1977 ford f250 custom with a 400. I was wondering the best way to make it run smooth . The exauhst is totally shot but I doubt that's the problem... I could get it to run but after sometime it will shut itself off after a bit. Another problem is assoon I put it into gear it stalls. What could ido to fix this? Any good ideas I will attempt . Thank you!!
Old Jul 28, 2011 | 01:11 AM
brian1080's Avatar
brian1080
When's the last time you tuned it up? spark plugs/wires/coil/fuel filter/oil change/etc? If it's been a while, start there. Next, fuel pump and or carb. Start with the smaller things and work your way in, at the very least you have all new components.
Old Jul 28, 2011 | 01:19 AM
decscorpion
I did new wires, cap and rotor , spark plugs . May do oil tomorrow... I think it's something to do with bad gas from sitting for a while. I had it running good , when I had it 5 years ago as my first car then I ran out of gas and it hasn't been the same sense.
Old Jul 28, 2011 | 01:23 AM
brian1080's Avatar
brian1080
try a new fuel filter, and check that the pump is working 100%
Old Jul 28, 2011 | 01:29 AM
decscorpion
How do I check pump? And would putting the expansive gas (91) in tank make situation anybetter?
Old Jul 28, 2011 | 01:38 AM
ArmyCook's Avatar
ArmyCook
If its been sitting a long time then it would be a good idea to go ahead and replace the fuel pump. The mechanical pumps that that truck uses runs between 20 and 50 bucks. hardest thing would probably be just getting to it to replace it.
Old Jul 28, 2011 | 01:41 AM
brian1080's Avatar
brian1080
I agree. my 78 wouldn't get any fuel from either tank when we went to pick it up. When I got it home, I ran a line from a gas can to an electric pump, to the carb and it fired right up. Mech pump didn't have enough suction to pull gas from the tank, let alone power to push it up to the carb.
Old Jul 28, 2011 | 01:46 AM
decscorpion
I have a suicide gas tank and there is no bed on the truck as of now... Idk if getting to it would be hard. Is there a way I could test if it's the pump?
Old Jul 28, 2011 | 01:48 AM
brian1080's Avatar
brian1080
the pump (if mechanical) is on the side of the engine, if it's got an electric pump it could be anywhere between the engine and tank. To see if you are getting fuel, you could pull the line off the carb and try cranking it. Be warned, if it is working you will spray fuel everywhere. On mine, when I pulle the line and cranked it, nothing ever came out.
Old Jul 28, 2011 | 01:17 PM
decscorpion
I'll test it... I think the carb might need cleaning... I may add a gas additive . As lOng as the pump is good
Old Jul 28, 2011 | 01:37 PM
devino246's Avatar
devino246
Add some new gas and maybe mix in a bit of seafoam. No point in using higher octane gas, the higher octane rating just means the ignition temperature is higher.
Old Jul 28, 2011 | 01:49 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
I had an 78 F250 Ranger with the 400 for 22 years before I sold it. Had to replace the fuel pump twice. Mechanical, front lower driver side. Each time the symptoms were as described. The one time it just died with no warning signs, as if out of gas and wouldn't start, it was the fuel filter. After that experience, at 4.00 for the filter, it got changed every other oil change.
Old Jul 28, 2011 | 02:03 PM
decscorpion
I'll change the filter too These seem all like cheap fixs
Old Jul 28, 2011 | 08:13 PM
ArmyCook's Avatar
ArmyCook
Yeah, a mechanical fuel pump and filter are pretty cheap to replace. If that solves your issue then great.
Old Jul 28, 2011 | 08:18 PM
devino246's Avatar
devino246
And if not then thats one less time your truck wont start on you in the future
