no spark from plug wires
Old Jul 27, 2011 | 09:40 AM
Cody_1948's Avatar
Cody_1948
Guys, after rewireing my 48.. Im not getting any spark from ends.. Could it be the coil ? also where do I ground the coil ??.. Also is the 48 neg or pos ground ??...
Old Jul 27, 2011 | 10:12 AM
52 Merc's Avatar
52 Merc
It could be several things, including the coil. You'll need to trace back and see where the last place you have power is.
You don't ground the coil, exactly. The stock electrical system on your truck was 6V positive ground. If that is the system you have re-installed with your rewire, on your coil, the + terminal goes to the points in the distributor, and the - terminal receives power from your ignition switch.
Old Jul 27, 2011 | 04:09 PM
hxgaser's Avatar
hxgaser
Ignition circuit should be straight forward. You should have a line from the ignition switch to the coil and another line from the coil to the distributor. That is it.
Check and see if the line from the ignition switch has 6V.
BTW, 48 is 6V positive ground if the truck is stock. The coil does not need to be grounded.
Old Jul 27, 2011 | 04:26 PM
oldmerc's Avatar
oldmerc
oldmerc
Cody
Check on line for the wiring diagram if you have not got yourself
a manual, but I think you will find the coil finds its ground through
the points.
Allan
Old Jul 27, 2011 | 04:46 PM
hxgaser's Avatar
hxgaser
I just realized that I pretty much repeated what 52 Merc said... What he said...
Old Jul 27, 2011 | 06:37 PM
52 Merc's Avatar
52 Merc
LOL...I thought I heard an echo in here.
Old Jul 28, 2011 | 06:08 AM
petey shoes's Avatar
petey shoes
don't forget to put the rotor in!! seen this way too many times.
gogoat
Aug 24, 2016 10:29 AM
mic687
Jun 11, 2011 05:45 PM
53rat
17
Oct 7, 2009 07:26 PM
mabigredtruck
Jul 5, 2008 12:45 PM
Jrock909
Aug 12, 2006 03:18 PM
