??? TUNERS ???
Old Jul 26, 2011 | 07:17 PM
Teds's Avatar
Teds
??? TUNERS ???
i have just purchased my 1st diesel...i did this in hopes of gaining fuel mileage that i couldnt get from gas after talkin to several people.....i am not wanting to use the truck to pull heavy loads or run at the drag strip even though getting on it a few times will be fun... i was going to order a K& n cold air and a bullydog, but after running across this website i am being told not to and was directed to this section being that its a 03 f250 crew 6.0.....i am walkin in the dark here and have no idea which way to go can u help.
Old Jul 26, 2011 | 07:22 PM
2006powerstroke90's Avatar
2006powerstroke90
Leave the stock air filter system on the truck. Its best for the motor.
I would not tune the truck with anything then a SCT tuner....But if you do not have head studs, I wouldn't run the risk of running a tuner...
Old Jul 26, 2011 | 07:25 PM
william_04_x's Avatar
william_04_x
Welcome Teds. Congrats on the new truck.
Don't waste your money on an aftermarket intake. Most do more harm than good. The factory set-up on these engines is excellent.
As far as tuners, I wouldn't run anything except an SCT with custom tunes.
Have you had the truck long enough to figure out what kind of mileage it gets now?
Teds's Avatar
Teds
i did call a ford dealer earlier to ask if anything w the head had been done they had nothing in the records.... is this a big deal? expensive?
Old Jul 26, 2011 | 07:26 PM
tex25025's Avatar
tex25025
First off tuners and/or intakes aren't a for sure thing about getting better mileage. You might see an improvement, you might not. You might even see a reduction in your MPG. It would be far better and cheaper for you to train your right foot a little more to eeck out as much as you can.
Don't do mods like the ones you mentioned for fuel economy reasons. They are performance mods, the companies have noticed a side benefit for some owners and that is something that they sell.
I would stay away from a/m intakes unless you plan on doing more mods then just a tuner. I have a bigger turbo, bigger injectors, bigger fuel pump and I still run the stock intake.
Also before you do any performance mods period get gauges to monitor the vehicle's vitals. In fact, do that anyway even if you don't mod the engine.
Old Jul 26, 2011 | 07:33 PM
cheezit's Avatar
cheezit
both of these questions are relitive to what one believes to be a big deal or expensive.
and in someway both questions seem rhetorical
Old Jul 26, 2011 | 07:39 PM
Teds's Avatar
Teds
let me give you a little more info.....i do have pillar w exhaust temp gauge and boost gauge. the exhaust is all 4" pipe from up by the block all the way back no cats w a 6" silverline tip...i looked at silverlines website and it looks just like their exhaust dont know for sure...before i purchased it had a stack up through the bed...had guy look at truck before buying he said the turbo looked good doesnt seem that it was run hard but what do i know.. truck has 125k drives and runs great just a small walking issue w front end that i am trying to track down...
Old Jul 26, 2011 | 07:41 PM
Teds's Avatar
Teds
thnx will....yes i have been getting mid 17-18 running 70 on hwy at 2000 rpm
i am already ahead of the game my f150 4wd supercrew gets 14 all the time
cheezit's Avatar
cheezit
swap the tires around and see if the problem swich sides or goes away. check ball joints and rod ends.
Old Jul 26, 2011 | 07:43 PM
Teds's Avatar
Teds
as far as big deal is this a deal where motor has to be pulled or is it a simple job??
Old Jul 26, 2011 | 07:45 PM
william_04_x
That's not that bad for mileage already. You can still gain a little more, but it'll take longer to recoup the expense of the hardware.
What size tires are on the truck?
2006lariat's Avatar
2006lariat
I have a banks six gun PDA I will gladly sell ya!
Old Jul 26, 2011 | 07:48 PM
cheezit's Avatar
cheezit
ok here we go. I do this day in and day out.. its how I pay my bills. I find doing heads both simple and repetive. I do them in cab per the workshop book. so here goes my standard disclaimer... I have never met you and can not attist to your mechanical abilities what I find easy to do many people find hard while others just find it time consuming and frustrating at best...
now with all that said warranty time to r/i heads is aprox 15 hours that does not include any adds or diag for the concern. the typical cyclinder head job customer pay is 25-30 hours depending on the truck and how it is equiped.
Old Jul 26, 2011 | 07:49 PM
Teds's Avatar
Teds
for the steering issue it looks like we are going to replace shock dampner, upper inner tie rod, and steer boit has lots of play)
Old Jul 26, 2011 | 07:52 PM
Teds's Avatar
Teds
has new tires 265, new ball joints... so in other words cheez abt 2500..
