Weak charging? I'm stumped
Old Jul 26, 2011 | 12:25 AM
Y2K1TON's Avatar
Y2K1TON
Did a search but couldn't find an answer. 2000, F-350,7.3, single alternator. This issue has been getting progresivly worse. The engine starts fine starter motor turns fine, not draining battery over night.
After initial start up the lights and any electrical components are weak and dim. It usually lasts less than a minute. It only happens on morning start up or after coming out from work to drive it home. It's not an outside temp issue it's been 100+ degrees in Ft Worth and doe's the same thing in 80 degrees.
One of the neg battery cables has a stiff spot and swollen so I tried another neg batttery cable in parallel with the facory one and no change.
Could the GPR be pulling to many amps or sticking? Any ideas where to start testing?
thanks for any ideas.
Old Jul 26, 2011 | 02:41 AM
BillyBob69's Avatar
BillyBob69
Sounds like it could be a flakey alternator. Take it out and have it tested at an autoparts store. They can check the output both with and without a load.
husker3in4
Escape & Escape Hybrid
Feb 18, 2019 11:35 AM
tidywhitey
Feb 21, 2011 09:01 AM
Killian88
1997 - 2003 F150
Jan 15, 2011 07:23 AM
weekendwarriorfsw32
21
Dec 20, 2007 09:44 AM
Kinville
1983 - 2012 Ranger & B-Series
Apr 1, 2006 10:10 PM
