Oh, and just about any mix of Ethanol in your gas isn't going to do what you're describing. Look at other things before you get on the anti-Ethanol bandwagon. My v10 runs just fine on 10%. Always has, always will.
There is a station less than 5 miles from my house on that list.
Rep sent.
So does mine, it just burns more of the blend than it does pure gas.
sensors are the first thing to come to mind, clean and or replace.
So today I replaced the O2 sensors..won't know with absolute certainty until I tow if my problem is fixed. But so far on my test run, she seems to get up and go much better and hits the 4k+ RPM range almost immediately when I put the foot to the floor. I was paying closer attention to the performance the last few days when accelerating quickly, and definitely sounded like the engine was struggling above 4k even without load.
So thanks everyone for the replies. Will probably do a test run with my TT this weekend to see for sure.
I ended up putting in the Bosch Premiums rather than Motorcraft...much cheaper, about $52/ea at Orielly's. Was gonna get the Motorcrafts, but twice the price.
WOW is there something wrong with me. I have never seen 4k on my tack I usually try to not even break 2k sometime i get to 2.5k but let off as i hate to pay for gas as someone is making money on me at the pump. Do you think I will glaze the cylinders doing this. I know bad spelling. I have 119k on the motor and she runs like a raped ape.
Towing up the mountains around here, I see 4800 regularly and hold at 4200 for long periods. No problem, it's what this V-10 is designed to do.
Absolutely...three years ago when I first started towing, I wasn't sure I should be running like that, but in research thats where the engine is happy. So up till now, its been running beautiful. Albeit, fuel economy at that level is non-existent, but the way I see it, if your concerned about fuel economy, you probably shouldn't be towing
I don't know about the 3v motors, but my 2v hated the bosch o2 sensors. They were much slower reacting than the MC. I did lots of research, and I ended up shaping out the Bosch and my mph and driveability came back. Also, the problems didn't start for about 4k miles after the fresh installation. Something to think about...
There is a customer satisafaction bulletin (10m05) from Ford that extends the warranty for a catalyst y pipe. U should have received the letter in the mail. This may be your issue. You have several of the symptoms.
I actually pulled that out of the filing cabinet lastnight. I remember that coming in but didn't have any concerns at the time when it came in. Its kind of vague on the symptoms, need to dig in a bit...but that did come to mind as something to have them look at. The cats are also covered, maybe I should just take it to the dealer and let them address the Y pipe and check the cats for me.
"Glaze" the cylinders? No. Just probably fill the engine up with carbon and the truck will adapt to that driving style and feel even more sluggish. At 2500rpm the engine isn't even close to its peak torque number which is lower than the peak hp number. Your not doing the engine any favors lugging it IMO. High engine load even at lower rpm isn't good for fuel mileage either.
PS my truck hit well over 4500rpm several times this morning.
So just an update since my last change to the truck...A few weeks back I replaced the O2 sensors (pre cat) but until this weekend didn't get a chance to get the rig out for a test. This weekend though we went camping and I think the O2 were the problem. Fully loaded the truck ran like I expect it to. No power loss when climbing and I was even able to accelerate if I needed while climbing. Held nice and steady above 4K with no issues what so ever.
No other changes were made since changing the O2 sensors. Towing both ways on two seperate days, 98 degrees out the first day, 78 this morning, she ran great both. In a couple weeks we go camping again, so that will tell if this weekend was a one off, but I'm confident after reading up on O2 sensors, the info from this forum, and advice from a colleague that this was the problem.
What part # did you use for the upstream O2 sensors? I have seen both the up and downstream sensor listed as the same part # and I have seenthem as different part #. I have the 2008 Lariat as well and need to replace them but dont know if they are identical or different.
